Page 1 of 9 123 ... LastLast
Results 1 to 10 of 83
Thread: Clunking when accelerating
    Regular Member Gazza36's Avatar
    Jan 2010
    Cornwall
    Default Clunking when accelerating
    Hi, when accelerating or decelerating I'm getting a big clunking as if the engine mounts were gone but they're all fine, could it be the clutch / DMF going? Any ideas appreciated, Gaz.
    Regular Member eaglepva's Avatar
    Up North
    bump
    Sodding Typical on Sea
    Could it not be the exhaust catching something? are all the under shields in the right place?
    Up North
    I sometimes get this clunk/bang when pulling away from a parking/trafficlights etc.
    morecambe
    39 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    could well be the exhaust the standard rubbers are crap dare i say it swap them for some ford rubbers alot better
    Reading
    Check the cv joint on the intermadiate driveshaft on the drivers side, I had a clunk everytime I accelerated or decelerated, I'd already checked engine mounts, radiator mounts and exhaust, but nothing wrong there the noticed the gaiter had split and had clarty grese everywhere when having tyres changed, fitted a new gaiter and packed up with new grease, clunking gone immediately, I only noticed it had stopped because it was so quiet, I didn't think that it could be the reason, but obviously, it was.
    Good Luck
    Mark
    Up North
    is the cv joint the rubber thing thats on the end of the steering rack ends (inners)
    Reading
    No, they're the rubber gaiters that protect the steering rack ends, if you jack up the car and take the wheel off, in the centre of the wheel hub there is a big nut, thats connected to the driveshaft, if you look behind the hub, it runs from the middle of the wheel hub to the Intermediate shaft on the drivers side, or to the gearbox on the passenger side, the cv joints are what couple the driveshaft to the gearbox and hub, they've got a rubber bellow on them that looks similar to the ones on the steering rack.
    Jan 2010
    Cornwall
    CV gaitors look alright, can the exhaust really make it feel that bad and is worth getting poly ones? Cheers, Gaz.
    Jan 2010
    Cornwall
    The CV's felt alright, no play between the shaft and the wheel anyway, and all the gaitors looked ok, gear selection isn't great, there's this clonking, there's what sounds like dmf style knocking sometimes, the clutch doesn't feel brilliant when changing gear either lol. How much are you looking at for doing the dmf?
  1. Juddering when accelerating
    By LAURA4014 in forum Vectra C / Signum Troubleshooting
    Last Post: 31st October 2012, 18:25
  2. help please .... Hesitation when accelerating
    By amir2300 in forum Engine & Drivetrain
    Last Post: 12th July 2011, 15:58
  3. Car Jumping When Accelerating
    By BigM in forum Engine & Drivetrain
    Last Post: 24th June 2011, 22:40
  4. Help !! Juddering when accelerating
    By johnny1983 in forum Vectra C / Signum Car Chat
    Last Post: 2nd March 2011, 17:33
  5. accelerating problem
    By lloyd_456 in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2010, 09:50
vauxhall Vectra 1.9 cdti drive shaft nut tightening
clunk under acceleration and deceleration vauxhall
vectra clunking on acceleration
vectra clunk on acceleration and deceleration
vauxhall clunk on deceleration
vectra clunk rev accelerating
