Thread: Thermostat housing bolts problem
    Feb 2011
    Belfast
    Default Thermostat housing bolts problem
    Sorry for so many posts/Queerys its just im having so much trouble at the moment.
    Local mechanic did a regular service for me today he was also to put in a new thermostat BUT he cant do the job.
    Reason he gave me was that there is 2 bolts holding it on and the bottom bolt head has sheered of and he cant get it off.
    He said he needs some tool to do the job (cant remember what it was)
    Does this sound like a thermostat issue?
    Car slow to heat up.
    When it heats up in traffic( need sits about half way on temp guage) i get some heat from heater but its not great.
    When i go onto the motorway the needle on the temperature guage drops right down to its lowest ?
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    9 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 210,022
    Sounds like the thermostat to me.
    I'd wager that he needs to drill out the sheered-off bolt and then use an Easy Out on it. It's a reverse-threaded tool that you wind into the drilled out bolt and, as it tightens, the remains of the bolt are unscrewed. I saw this actually work last weekend! First time for everything!
    Anyway, the problem will be access to the errant sheered bolt to get the drill into it. Do-able, I'd think but lots will need to be removed to make space.
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    Jul 2009
    The Rift, Cardiff
    I notice you have the 1.8 non vvt. The housing is not threaded so the bolt should move freely through it, maybe it was just the gasket holding it in place. If it's just the head that has snapped off then it should be easy to remove the rest of the bolt with mole grips or a wrench once the housing is off as there should be a cm or so sticking out of the block.
    9 Post(s)
    Trim : GSi
    Engine : Z32SE
    Mileage : 210,022
    ^^ This is true. I should have said, "The problem might be..."
    If the above it true, then the difficult bit may be prying the cover off. Shouldn't be too hard, though, if you can get the other bolt out.
    Paul
    Feb 2011
    Belfast
    Ok thanks guys was talking to a different mechanic,he said he will sort it out on monday hopefully that will be one of my problems solved fingers crossed
    Feb 2011
    Belfast
    Sorted a proper mechanic did the job for me
  1. Thermostat housing
    By Robhousing in forum Vectra C / Signum Troubleshooting
    Last Post: 24th September 2012, 18:54
  2. thermostat housing
    By alan66 in forum Engine & Drivetrain
    Last Post: 10th September 2011, 16:01
  3. thermostat housing
    By andy bo in forum Engine & Drivetrain
    Last Post: 27th July 2011, 12:54
  4. Thermostat Housing
    By coopey in forum Vectra C / Signum Car Chat
    Last Post: 14th June 2011, 10:35
