hi all, my beloved 1.8 sri gets to normal running temp then drops to cold, right to the bottom then strugles to get 2mil above cold,
any ideas, before a guy in a vauxhall overall sucks his teeth and charges me a fortune!
Highly likely to be a faulty thermostat, which is stuck in the open position. Whilst winter time can cause engines to take longer to heat up, once they're at the correct operating temperature the needle should never drop to the bottom reading again while the engine is running.
thanks, get it checked asap. will this cause damage if driven like this?
defo thermastat mate mine was the same changed it last week and its sorted it .dont think it will damage it i drove mine for about a year before a changed it.
Won't cause damage, but MPG will be worse.
cheers folks
