Results 1 to 10 of 24
Thread: 3.0cdti turbo problem
    Jul 2010
    leicester
    Default 3.0cdti turbo problem
    hi can anybody share some light on this-i have a 2006 3.0cdti signum-and last night it went into limp mode.
    the fault code shows-P0235 - Turbocharger Control Module Malfunction
    (50) - Present
    is this just a module that can be replaced-or is it the whole turbo?
    any ideas where this module is located?
    The car has been running fine until this happened-no black smoke or anything like this.
    any feedback would be greatly apreciated
    Regular Member Jezzy's Avatar
    S.E
    My lists of fault codes say it's not a "control module" per se, it's the boost sensor that's reporting the fault. A Vx dealer should be able to give you a price, even if you end up buying it somewhere cheaper.
    Jul 2010
    leicester
    Wow that was a quick reply-thanks.I think ive read that these can be cleaned somewhere on this forum-now i just need to find out where in the engine its located!
    thanks again for the quick response
    S.E
    You're probably thinking of an EGR (Exhaust Gas Recirculation) valve that can be cleaned - if it's the boost sensor then you're better off buying a new one. I'm just having a look on the parts catalogue to see if anything jumps out at me as being the boost sensor on your engine model, problem being that Vauxhall use fancy terms for these components sometimes.
    you can clean them , should be located at the back right of the engine under the engine cover
    S.E
    I'm hazarding a guess that it's item number 17 in the picture below; it's described by Vauxhall as being a "Sensor, vacuum, inlet manifold pressure" - and obviously therefore located near the inlet manifold. The part number is 97353014, about £70-90 from Vauxhall, so if what Mark says above is true, worth cleaning before commiting to paying that much for a replacement.
    just tried to find the old thread about where big sig showed a pic of it in the engine bay but having no luck
    looking at that pic jezzy it looks more like number 15
    S.E
    You mean I have to boot up EPC again??? lol
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    It's under the red arrow. You'll spot it easily...it says HITACH BOOST SENSOR on it http://www.motor-talk.de/bilder/kann...203742073.html
    S.E
    Quote Originally Posted by marktaylor View Post
    Number 15 doesn't have any part number or description, meaning it's not a valid part any more.
  1. Your opinion on diesel smoke problem on 3.0CDTi
    By Celes in forum Engine & Drivetrain
    Last Post: 17th November 2010, 14:00
  2. Boost pressure problem - 3.0CDTI
    Last Post: 31st October 2009, 00:10
  3. Tyre wear problem on 3.0CDTi
    By BishBoshBash in forum Suspension, Wheels & Brakes
    Last Post: 22nd September 2008, 18:15
  4. Turbo Problem...
    By dankidd in forum Engine & Drivetrain
    Last Post: 11th August 2008, 22:55
  5. 2.0 DTI turbo problem
    By Vibez_Uk in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2008, 21:15
3.0 cdti turbo control module
