Results 1 to 10 of 11
Thread: blanking plate
    Oct 2010
    york
    Default blanking plate
    cars not very well pulls great to 3000 revs but then theres an awful vibration from the engine and a lack of powerful acceleration. for a 2.2 very slow, some think egr if so got a blanking plate, but do you have to get it remapped?
    Some think its a valve sticking, while ive been told it could be fuel related, surely someone out ther must have had the same problem and knows what it is PLEASE.
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    If its a 2.2 petrol them wait till I get home and i'll go through it with you. Im on my phone so cant show you all the pics. Ive done mine and you dont need a map for the petrol.
    Vehicle : SRi
    Mileage : 137000
    Petrol or Diesel?
    Oct 2010
    york
    petrol manual
    Vehicle : SRi
    Mileage : 137000
    Right, if you blank the EGR alone you still have to have the EGR plugged into the loom. This is because the ECU only monitors the actual movement of the valve, if the valves not there then it throws a fit, and because of this the EGR has to be working properly.
    Alternatively you can blank the EGR, totally remove it and have the dealer Tech 2 it out (around 55 to 70 quid).
    There is one more option however and it will cost you an extra £10. If you visit the shop on the 2.2 forum (z22se.co.uk) you can buy a little box of tricks made by one of the mods (Vocky). All you have to do is blank the EGR, totally remove it from the car and where it plugs into the loom just plug in the Cheater, this fools the ECU into thinking its still working perfectly.
    Blanking your EGR will cause you to lose some MPG, but only very slightly.
    Personally, I would just take off the EGR and give it a good clean, and make sure it works like THIS when you pass 12v over pins A & E.
    This is how mine looks blanked.
    As you can see the EGR is still bolted to the side of the mount, this is so its not flying around inside of the engine bay and its still plugged into the loom, and its offset so the plunger can still freely move up and down without getting caught on the casting.
    HTH
    Steve
    Vehicle : SRi
    Mileage : 137000
    Vehicle : SRi
    Mileage : 137000
    No need to say thanks.................
    Regular Member Tam80's Avatar
    Aug 2010
    Dundee-Motherwell
    Rushy...Is The Round Silver Thingy The EGR Then ?
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by Tam80 View Post
    Yes mate, but this only works on the 2.2 petrol, Unfortunately not on yours mate. Its just a solenoid, that pushes a plunger into a hole in the block.
    Oct 2010
    york
    thanks rushy sorry for not saying it earlier as i have been that busy at moment and just tried it yesterday. the egr doesnt seem to be working and have done this seems alot better. question is does the egr valve have to work while its in this position please? And thanks for your answer in advance.
  1. For Sale: DTi EGR Blanking Plate
    By TonyP2020 in forum Parts for sale
    Last Post: 8th November 2012, 00:10
  2. Egr blanking plate
    By morrisseyno1 in forum Vectra C / Signum Troubleshooting
    Last Post: 10th September 2011, 20:49
  3. Egr blanking plate
    By baz_cdti_sri_150 in forum Diesel Engine related
    Last Post: 2nd April 2011, 19:51
  4. EGR Blanking plate.
    By stuart813 in forum Engine & Drivetrain
    Last Post: 5th June 2010, 17:36
