Results 1 to 10 of 14
Thread: Knocking at Front......... Help
    Regular Member johnny1983's Avatar
    Ryton, Gateshead
    Default Knocking at Front......... Help
    For a few months, i have had a knocking at the front at low speeds. It isn't loud but quite annoying really. The car is a 2006 1.9cdti sri.
    My car is lowered on Eibach 30mm springs so not sure if it has affected it recently.
    Has anyone encountered this problem and found what teh remedy is? I have just recently had shockers changed and that hasn't made any difference.
    I can get it to do it when driving at low speeds and violently steering left and right, but it is there when driving over bumps in the road.
    Many Thanks
    Regular Member Jezzy's Avatar
    S.E
    If it's there when you go over bumps then it's probably caused by worn anti-roll bar (ARB) bushes. There's a How2 on here for how to replace them, and they only cost a few pounds to buy from Vauxhall dealers.
    Ryton, Gateshead
    Brilliant, thanks for the quick reply !!
    Regular Member mickydoos's Avatar
    Aug 2009
    Crawley, West Sussex
    Also try replace the drop links. I just solved an annoying knock by changing them. Again, there's a how2 on here on how to do it.
    Regular Member Exclusive BV's Avatar
    West Midlands
    also check your brake pads arent rattling around in the carriers
    Derbyshire
    Mines doing this at the moment, & its the droplinks my friend.
    If the noise is like your exhaust banging on the body (but its obviously not your exhaust!) then this is what it'll be.
    wales
    mine is the same i will be looking at the drop links now...
    Feb 2011
    Stockton On Tees
    Must be a common problem as ive just had to buy the drop links also
    wales
    done the front links perfect but now my back shocks are squeaking
    Regular Member MCD's Avatar
    NE Manchester
    35 Post(s)
    Vehicle : 2007 Vectra
    Trim : SRi XP T Saphirre Black
    Engine : z20net
    Mileage : 80k
    I have similar issues... Lowered on eibachs, been fine for over a year. Recently got slightly knocky at slow speed at front.
    Thus far done drop links, anti roll bar bushes, cleaned stuff, greased stuff. Check springs and spring seat mod.. All ok! Put shims in brake pads so silent.
    Still a knock... Intact, non of the above made any significant difference. Car drives perfect and true, no play in steering wheel.. I'm at a loss!
    Mike
  1. Knocking from front
    By RBH in forum Suspension, Wheels & Brakes
    Last Post: 12th September 2011, 18:51
  2. knocking from front end
    By danny_n in forum Suspension, Wheels & Brakes
    Last Post: 14th July 2011, 14:40
  3. Knocking at front
    By NikNakNok in forum Engine & Drivetrain
    Last Post: 7th June 2010, 12:09
  4. knocking front end
    By VECTRA HEAD in forum Suspension, Wheels & Brakes
    Last Post: 10th May 2009, 20:24
  5. Knocking Front O/S
    By Ralph wiggum in forum Vectra C / Signum Car Chat
    Last Post: 5th December 2006, 19:40
