Results 1 to 10 of 19
Thread: auto electrician
    Feb 2011
    notts
    Default auto electrician
    just after some advice please, i cant stop my alarm randomly going off on my vectra estate sometimes it can be going off allday then for no reason will be fine for days. anyway ive rang a couple of auto electricians they both said that its much easier to disable the alarm rather than spend all day traceing the fault. they said it will not affect the immob or central locking or anything else on the car.
    just wanted to check if anyone else had a similar thing done, all help much appreciated thanks
    Regular Member Craig1985's Avatar
    harwich essex
    A tech 2 session may pic up a faulty sensor. Have you tried pressing the alarm button near the stereo, I think this disables the interior sensors?
    Feb 2011
    notts
    yes mate tried doesnt make a diff, whats a tech 2 then a full electrical check to check were there fault is.
    have you heard of anyone haveing the alarm taken off?
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    Noticed in your profile you have an estate. Check the sensors on the rear side windows (boot area). There are sensors attached to the bottom of the windows (you need to remove the shelf supports to get to them) and it's VERY common on estates that these come away and is a very common cause of your symptoms.
    Feb 2011
    notts
    thanks for that, so basically you mean the sensor will just want to be plugged back onto the re side window?
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    They have a habit of pulling off the glass, it's a metallic strip basically.
    Best pic I have to hand, you can see the connector in this one...
    Feb 2011
    notts
    top picture that mate realy appreciate it, is it the 2 on the bottom left of the picture then obviously the other window. i`ll get out and have a look asap fingers crossed its that simple.
    Worcs/Staffs/Westmids (ish)
    Try using the button on the dash to turn off the interior sensors...... If that stops the problem, then you know a sensor has gone.
    Other top causes are the alarms internal battery starting to fail (makes the car think it's being stolen), door/boot/bonnet open switch water ingress and connector corrosion.
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Quote Originally Posted by Birchy63 View Post
    He's already tried that, said so earlier in the thread
    Quote Originally Posted by Ian-Highlander View Post
    I didn't see, I'm trying to do some covert forumising (thats American btw), while im sat at work
  1. auto electrician
    By SarahP in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2012, 09:35
  2. me thinks i need a auto electrician in or around the blackpool area
    By 6009tristanb in forum Electrical & ICE (including SatNav)
    Last Post: 26th March 2012, 19:32
  3. auto electrician
    By marc vectra sri in forum Electrical & ICE (including SatNav)
    Last Post: 22nd November 2011, 14:56
  4. auto electrician leeda Area
    By dannydm1 in forum Electrical & ICE (including SatNav)
    Last Post: 6th October 2011, 07:34
  5. anyone reccomend a decent auto electrician in kent
    By jon1.9cdti in forum Electrical & ICE (including SatNav)
    Last Post: 30th July 2010, 00:16
