Results 1 to 10 of 15
Thread: Corsa Advice - Burning oil (Yes i know its a vectra forum!)
    Regular Member Knuckle's Avatar
    South
    Default Corsa Advice - Burning oil (Yes i know its a vectra forum!)
    Hi guys,
    I've asked on the Corsa forum but its completely useless so hoping some of the tech heads on here can offer their thoughts.
    My girlfriend's corsa is buning oil at a rate of about 1 litre to 500 miles if not worse. I hear that they usually burn oil at worse 1 litre to 800 miles.
    Her chain and tensioners are noisy as hell so they are getting renewed tomorrow, but im worried about the oil (could it be that the engine noise is something worse...) - definitely isnt leaking and there isnt any blue smoke, although giving it some beef parked up earlier it did appear after a while to puff out some fairly dark smoke.
    Its a 1.2 sxi 2003 and currently has 5-30 oil in it i think.
    Any suggestions on what tests to do and what to look out for?
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Mileage? Possibly hardened Oil stem seals? If it was these you'd normally notice it at start up as a puff of blue smoke.
    South
    60k but she has only owned it for the last three
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Our 1.2 SXI done the same and the 1.6 Sport too. Never did find the cause of the fault before we got rid.
    Gazza4
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    The vast majority of Corsas drink oil but not normally like that. Mine used to go through a litre every 800-1000 miles. Who owned it before you? Any chances it has been ragged to death by a previous owner? I for the life of me can't remember which oil I used to put in mine.
    Which forum did you post on? I'll ask on Corsa-c.co.uk if you like. Still a member and the technical help is usually good. They do know their stuff.
    Had a think and the only things I can come up with are worn rings, headgasket or worn valve guides. Will muse it over tomorrow though when I'm a bit more awake and with it. Anything in the coolant bottle?
    South
    cheers for the input, went to my garage that i trust today for the chain but fortunately very honest and told me the chain and tensioners were quiet as anything.
    It was the waterpump bearing, bizarre. so anyway that has been changed, the coolant changed, oil flushed, protection stuff added and then oil change.
    runs quietly now.
    now the bad news. had new spark plugs too, on removal of the old ones, it is clear that oil is getting to them (cylinders 2 and 4)
    They couldnt find anything wrong with it though, so hoping that the nice good quality oil and clean out will reduce the rate of consumption.
    Just going to have to keep a real eye on the levels i think!
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    sell it mate i would
    South
    Dont think she wants to sell it mate, the garage weren't that overly worried about it either and were hopeful that the fresh oil will really help.
    but yeah if the oil consumption gets really bad then its back to the drawing board.
    Regular Member Keif's Avatar
    In the Garage
    I use Vauxhalls 10-40 Semi synthetic oil in the wifes Corsa C.
    5-30 is a bit thin really.
    South
    5 30 fully synthetic went in, it is thin but what's recommended. going to run with this and then if it continues to burn excessively switch to 40,
  1. vectra burning?
    By marc vectra sri in forum Vectra C / Signum Troubleshooting
    Last Post: 9th December 2012, 11:15
  2. fat burning supplements advice
    By rob warrington in forum The 'Off Topic' room
    Last Post: 23rd March 2012, 08:06
  3. 1999 T reg corsa service advice
    By rob warrington in forum General Motoring Chat
    Last Post: 4th March 2012, 23:35
  4. Corsa C problem - Video of noise and burning oil
    By Knuckle in forum The 'Off Topic' room
    Last Post: 12th April 2011, 17:41
  5. Any Corsa C experts in this forum?
    By george1987 in forum The 'Off Topic' room
    Last Post: 10th March 2011, 15:02
vectra c how to stop burning oil
