Results 1 to 10 of 14
Thread: Traction Control and ABS question
    Regular Member Knuckle's Avatar
    South
    Default Traction Control and ABS question
    Hi all,
    In my quest to know all about the Vectra, do all have traction control?
    I understand some fit switches to turn it off, but im certain mine doesnt. It popped a nasty wheelspin in the wet the other day and nothing came on.
    (2006 55 2.2 SRI)
    I also notice the ABS is quite sensitive if you brake hard, more so than my previous cars.
    Full Member GazVXLINE170's Avatar
    Jun 2007
    Scotland
    Vehicle : Insignia
    Trim : SRI VX-Line Nav
    Engine : 2.0 CDTI [170 PS]
    Year : 2015
    Mileage : 27000
    Probably not. The real way - not 100% - to tell is open the bonnet, and behind the battery compartment there is the ABS module (silver box with tubes coming out of it) if you look at the side which faces the engine block I believe it will say 'TC'. It will tell you have ESP or not at least anyway.
    Gazza4
    Insignia VX-Line Nav CDTI 170.
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    As Gazza says, the label on the side of the ABS module will tell you.
    If it says ESP, you have ABS, Traction Control and ESP
    If it says ABS and TC, you have ABS and Traction Control and no ESP
    If it says ABS only you have ABS but no Traction Control and no ESP.
    Simples.
    South
    Cool cheers i dont care either way, never really found traction control on any car useful in any situation other than in heavy snow/ice. was just interested to know if something isnt functioning.
    going to be making a few adjustments on the weekend so will take a look then.
    5 Post(s)
    Quote Originally Posted by Knuckle View Post
    NCT5 tyres fitted?
    South
    What make are they? Think i have Goodyear on front Michelin on rear
    5 Post(s)
    If they're Goodyear NCT5's, that'll be the reason. They offer poor grip - hence why they last a long time.
    Get shot of the ditch finders (No Contact With Tarmac) for some tyres that will give you some grip.
    South
    Ah I see may be why then ! I always thought Goodyear were some of the best!
    Oct 2006
    Waterloo, Liverpool
    Trim : SRI NAV XP
    Mileage : 72K
    NCT5's are OK unless you drive the car like you stole it.
    Quote Originally Posted by john_k_sri View Post
    Simples.
    just been checking the sig to see if its worth fitting a t/c switch
    the abs module has ESP on it so assume i have ABS,traction control and ESP.........but
    no wiring plug in the dash behind the blank ????
  1. random question.... Sport and traction control button
    By Collis in forum Vectra C / Signum Car Chat
    Last Post: 17th February 2011, 19:22
  2. Traction control question?
    By john1 in forum Engine & Drivetrain
    Last Post: 3rd December 2010, 20:53
  3. traction control question
    By aerodynamic18 in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2008, 01:36
  4. Facelift Question regarding traction control
    By Pronto13B in forum Vectra C / Signum Car Chat
    Last Post: 13th March 2007, 18:02
  5. traction control ... again
    By fireblade in forum Handling & Braking
    Last Post: 25th April 2006, 08:28
