Results 1 to 10 of 13
Thread: Airbag light won't turn off
    Feb 2011
    Bradford
    Question Airbag light won't turn off
    Hi everyone, hopefully I've got the right section, I recently replaced my MAF on my 1.9 cdti Vectra, I tried a second hand one from a breakers yard, turns out it was off a different model.
    Plugged it in, turned the ignition on and tried to fire it up, there was a 'pop' and then it wouldn't start. Turned out one of the fuses near the passenger door pillar had blown.
    I changed the fuse and the car fired up fine, only thing is that the airbag light was now on. Took it to the local garage, a non-vaux one, he plugged it in and there were 2 codes, one related to there being an interruption in the power supply, which he cleared, the other was a P0650 code, apparently a MIL malfunction.
    I've been advised that the instrument cluster can be refurbed or I could get a new or second hand set.
    Does anyone know what the pitfalls of a second hand set of clocks are? Any dos or donts, things to look out for?
    Thanks for any help, Vince.
    stockport
    Arrow
    Quote Originally Posted by ssxanti2 View Post
    Whooo there!!!.Don't go throwing money at anyone until you know for certain what the problem is.First thing you do is disconnect your battery for a couple of hours and see if that clears it.In most cases it will.If it doesn't THEN get it coded properly,with a definate diagnosis,and take it from there.Some mechanics are all to happy to say anything to get their hands on your dosh!! FELIXX.
    Feb 2011
    Bradford
    Thanks for that FELIXX, I'll go and disconnect it for a while, fingers crossed it might help!
    DERBY
    dont think you can clear airbag light that way , you will need something to read the code to understand if its present or not , if you find a guy on here called plasma he may be able to give you some direction of what to do ,
    Jan 2010
    glasgow
    as said disconect the battery for a hour or 2 mind you have the radio code see if the ecu reset clears the airbag light also some code readers wont let you reset a airbag abs lights etc it all depends what is used to clear the codes some times after so many starts it will clear its self if the fault isnt present but it will still have it stored
    Feb 2011
    Bradford
    Quote Originally Posted by hoochydady View Post
    Thanks for that, I disconnected the battery overnight but it was still showing the light and saying 'airbag' in the display. The guy who plugged it in managed to cleat the first code, the interrupted supply, think that's what it was anyway, but the other one kept coming back, the P0650 one!
    The machine he used was made by Snap-on and he reckoned it had set him back about £5k, and £750 a year for updates, not sure the exact model, though.
    I'm thinking this could get painful in the wallet
    Regular Member Craig1985's Avatar
    harwich essex
    Opcom or tech 2 will def clear an airbag light as along as there is no present fault. There is a thread called "tech help near you" or summat like that. See if anyone local to you will try resetting it for you?
    harwich essex
    Feb 2011
    Bradford
    Quote Originally Posted by Craig1985 View Post
    From what the guy at the garage said there seems to be a fault present, even though he cleared it, it came straight back.
    Feb 2011
    Bradford
    Cheers for the link, looks useful!
  1. turn airbag light off
    By krazylegz in forum Electrical & ICE (including SatNav)
    Last Post: 31st May 2012, 17:48
  2. AIRBAG light .. is thier a fuse the the Airbag ecu ?
    Last Post: 10th September 2011, 13:21
  3. turn abs light off
    By twaiter in forum Electrical & ICE (including SatNav)
    Last Post: 4th May 2010, 18:25
  4. Passenger Airbag turn off?
    By keith1983 in forum Electrical & ICE (including SatNav)
    Last Post: 8th December 2008, 23:35
  5. Service Light: How to turn off?
    By barkzz in forum Electrical & ICE (including SatNav)
    Last Post: 15th September 2008, 19:16
vectra c passenger airbag light on
airbag light vectra c
airbag light on vauxhall vectra c 2015
airbag light wont go off on a vectra
how easy to get airbag light off vectra c
