Thread: CD70 fitting
    Regular Member leonvectrac's Avatar
    south shields
    Default CD70 fitting
    I have recived my cd70 from the bay today. I need some help with the connections, i have the wire that connects to the aerial base then theres a connection block on the other end
    Where does this connect too? What side do i run the wires from aerial base too front of car?
    and then theres these wires that come from rear of cd70 then wer too?
    south shields
    Haway people someone must know this??
    south shields
    Quote Originally Posted by leonvectrac View Post
    Guess no one knows
    Would be nice to find out for in the morning
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    The 1st pic is the block connector that clips in drivers side footwell and is joined together with another bit similar to that witch has rear aerial loom.
    All I did was use the navi part of that loom and then tape them together
    So in summary just remove the navi part of the big loom and fit aerial base on then plug in the plugs you have all ready at rear base and feed navi part along rear roof lining and down to front A pillar and tape it together under dash with the navi aerial in pic 2 then ug into back of stereo HTH
    Irmscher Insignia CDTI 130
    south shields
    Thanks for your reply bigmac i read it this morn and set about fitting it. but i decided to just fit the wire that came with the cd70 from the aerial base to as far as the drivers door then i thought i would remove my head unit to see were to route the rest of the wires. Which is when i came across the first problem the old head unit was in so tight i managed to slice my thumb open
    after swearing at it tryin to stop it bleeding i gave up as i slit my right thumb and am right handed so would be difficult finishing it!
    Anyway bigmac i was woundering if you know when i get that block connector in drivers footwell which way do the round pins in the second pic with the brown and green plastic on go in the connection block?
    i hope to get it done maybe sunday when me thumb heels a bit lol
    Devon
    75 Post(s)
    Vehicle : insignia
    Trim : irmscher
    All I did mate was join the 2 aerials together with electrical tape I didnt bother with the block seemed to much hassle when taping them together does same job
  1. rca converter for fitting sub to cd70 nav
    By lochgilp in forum Electrical & ICE (including SatNav)
    Last Post: 10th February 2013, 21:54
  2. Fitting a sub to cd70
    By Keith Fusco in forum Electrical & ICE (including SatNav)
    Last Post: 25th August 2012, 15:03
  3. help required fitting cd70 sat nav
    By deano1 in forum Electrical & ICE (including SatNav)
    Last Post: 20th September 2011, 19:58
  4. Help fitting the CD70
    By TopRod in forum Electrical & ICE (including SatNav)
    Last Post: 18th November 2010, 11:09
  5. CD70 fitting help!!!!!!!!
    By m3ath3ad in forum Electrical & ICE (including SatNav)
    Last Post: 11th March 2009, 21:22
how to fit cd70 in vectra site:www.vectra-c.com
