Thread: Confused!!!
    Regular Member tammyman09's Avatar
    tamworth
    confused Confused!!!
    Going back on the foglight subject. I recently posted about op-com my fog lights. now because im so miffed with it, i plan to retro them on monday, but befor i do, i thought i should ask this question.
    How can the UEC say that fogs are enables as is the rest of the settings. OP-COM read that the switch is sending a signal. and signal is being recieved, and both bulbs test ok even powered them off a 9v battery to prove they did. but why cant the car switch them on, because all i keep getting after switching on the option on in the uec is a bulb failure warnings on both lamps.
    can anyone offer any ideas? cause it has got me!
    cheers
    Sean
    tamworth
    bump
    tamworth
    Bump... Anyone?
    VIP-Member Das's Avatar
    Turdsville
    37 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    I think someone like Plasma or kemp would be your best bet with a question like this.
    I retrofitted front fogs and did loads of reading on here and the biggest issue is the UEC, in that whether you have one that supports front fogs in the first place is the biggest issue. Not having a clue about Tech2 and what it activates without the correct UEC i'm only grasping at straws, sorry.
    I take it you have tried plunging them in to the loom behind the bumper after activating the fog light setting?
    tamworth
    i hooked them into the loom forst then tried to activate them, so it might of been wise to have activated then plug them in? well I will give it a go any way!
    Admin & Merchandise Manager bigmac's Avatar
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    Your problem is the UEC this needs changed, Opcom and tech2 work a little differently, In tech2 if the Option for fogs is not available it will say "not programable" meaning it's missing in the UEC so can't activate it.
    Opcom works differently as it can set non programable options to present rewriting the modules code.
    Now sometimes this can work but other times it can't and can cause damage, Only option is to fit new UEC it takes 10 mins top then get it reprogrammed by tech2
    Irmscher Insignia CDTI 130
    tamworth
    Quote Originally Posted by bigmac View Post
    oh well, i will hard wire them in on their own switch...mainly cause i have no idea which uec i need to buy!!!
    cheers for the help anyways!
    Sean
    Devon
    67 Post(s)
    Vehicle : insignia
    Trim : irmscher
    http://cgi.ebay.co.uk/vectra-c-fuseb...c#ht_500wt_922
    Most Sri Vectras have fogs plus look for the White fog relay
    tamworth
    thanks for that...no when pay day arrives on monday, i might just order one of them instead!!!
    Thanks sooo much for letting me know this valuble bit of info
    VIP-Member sulten's Avatar
    Øvre Årdal, Norway
    Have you checked that you have the correct wiring?
    Correct fuses installed?
    Compatible light switch?
    You also have to activate fogs in IPC(instrument)
    Kristian
    68 Diplomat-A 46S
    95 Vectra-A C20NE
    07 Vectra-C Z19DTH
  1. Confused
    By Gubmint Agent in forum Vectra C / Signum Car Chat
    Last Post: 17th March 2011, 08:32
  2. How confused am i
    By 21_03_sxi in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2011, 22:36
  3. Confused???
    By monty2000 in forum Vectra C / Signum Car Chat
    Last Post: 19th February 2010, 11:31
  4. I'm well confused now.
    By shan in forum The 'Off Topic' room
    Last Post: 28th January 2009, 10:12
  5. Confused About Car Key
    By Hynzy in forum Vectra C / Signum Car Chat
    Last Post: 21st January 2009, 22:54
