Results 1 to 3 of 3
Thread: Engine cut out
    Regular Member derby4life's Avatar
    North,Shropshire
    Default Engine cut out
    when going to over take anything in my zafira 07 1.9 150 when I drop it down a cog and floor it the engine just stalls ....stops...nout I have to restart the thing ....no EML or anything very strange I have had the 1000 mile inspection light on recently...ish .....any ideas
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    If it's a 2004/2005 registered model I would say the throttle body is at fault. Strange though it only happens when changing down more likely when you are flooring it although that to sounds dubious.
    Gazza4
    North,Shropshire
    Quote Originally Posted by Gazza4 View Post
    Gazza4
    cheers gazza ...I can floor it normally in any gear and its fine but if going along in say 4th and wanted to overtake some one and I dropped down into 3rd then floored it just cut out completely
  1. 1.9 cdti Z19DT estate engine juddering plus white smoke coming from engine bay
    By danedragger in forum Vectra C / Signum Troubleshooting
    Last Post: 25th January 2013, 17:44
  2. Can I replace a Z19DT engine with a Z19DTH engine, fairly easily?
    By Krusty3380 in forum Engine & Drivetrain
    Last Post: 13th August 2012, 15:24
  3. Replies: 35
    Last Post: 5th May 2012, 15:32
  4. Yellow engine light staying on & engine getting hot.
    By Phil Campbell in forum Engine & Drivetrain
    Last Post: 20th March 2010, 08:56
  5. Replies: 3
    Last Post: 28th April 2009, 19:49
