Thread: whistling turbo
    Thetford, norfolk
    Default whistling turbo
    I have noticed that my turbo is making an over loud whistling noise over the last week or two. Does this mean its on its way out???
    Regular Member SRI_STU's Avatar
    Nov 2009
    solihull, birmingham
    Hi, yeah by the sounds of it. My old veccy was a loud whistler, especially 1st thing in the morning. I was told it was due to having the wrong oil put in at some stage but wether that is true i dont know but still had to have a new 1 put on which grieved me because it still worked fine.
    Thetford, norfolk
    Is it worth getting an uprated turbo or just replacing it with the standard part? Is it also a proper pain to change on a 1.9CDTI SRI 150, 55 plate?
    Nov 2009
    I had a standard 1 put back in, my mecanic charged me £120 to fit so wasn't worth getting my hands dirty. Dont think there meant to be that hard to do, but its too cold out there at the mo to be playing cars.
    Thetford, norfolk
    Too cold!? Its sunny and warm here!! How much are turbo's costing now days then? Any ideas??
    South Central England
    17 Post(s)
    Vehicle : Vauxhall
    Trim : very
    Year : Nosey
    An exchange unit from VX should cost about £450, plus the parts to fit it and labour you may be looking at £800. If you leave it, it the bearing will likely start dumping progressively more oil into the engine and will eventually not boost anymore. If it failed catastrophically, it could cause engine run away, where the oil becomes fuel in the engine and it keeps running until the oil is gone. That could write of the whole engine.
    You should be using a 5W-30 or 0W-30 and only fully synthetic. Anything thicker (10W-40 being a commonly listed diesel oil) could cause starvation of the turbo bearings and result in failure.
    Nov 2009
    I bought a 2nd hand turbo on the manifold, it came out of a 08 plate with 23k. The turbo looked like brand new and I paid £150 delivered so not too bad.
    Regular Member Mopar Man's Avatar
    herts
    As i haven't heard it i cant tell.
    I would check your inter cooler pipes first for leaks, as these can make a similar noise.
    Thetford, norfolk
    Thanks for all the info, is there a how 2 or any pics that could show me where and what im looking for??
  1. Turbo making a louder whistling noise
    By stupot555 in forum Engine & Drivetrain
    Last Post: 28th March 2012, 22:30
  2. 1.9cdti Turbo - Very Loud Whistling/Spinning Up
    By countduckula55 in forum Engine & Drivetrain
    Last Post: 19th January 2012, 00:02
  3. 2.0 turbo whistling over 3500 revs
    By tomo41 in forum Engine & Drivetrain
    Last Post: 27th August 2011, 07:55
  4. whistling noise after fitting turbo back sstem
    Last Post: 17th August 2011, 22:52
  5. Whistling CDTI 150
    By davidh in forum Engine & Drivetrain
    Last Post: 12th July 2009, 14:43
