Thread: 2.2 Direct Post Cat Lambda Sensor!!!
    Scunthorpe
    Default 2.2 Direct Post Cat Lambda Sensor!!!
    My 2.2 Direct SRi Vectra keeps firing up fault code P0141.
    P0141 - o2 Sensor Heater Circuit Bank 1 Sensor 2
    According to my local dealer it is the post cat lambda sensor!
    Obviously it is after the cat but can anyone tell me exactly where it is (pictures if possible) and does anyone know how easy it is to change myself?
    Cheers Tom
    Regular Member markj23's Avatar
    Aug 2010
    Luton
    underneath in exhaust with a cable coming out of it
    sensor 1 is in manifold back of engine
    sensor 2 is back of first bulge or is on my Signum
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    you will find it under the car near the flexi section of the forward end of centre exhaust pipe, so basically its just below the stereo area if that helps. The wire however will feed up the back of the engine bay to the connector. You can remove the sensor yourself but you may find it is well and truly rusted in. Jack the car up as high as you can (using stands of course) to give yourself the maximum amount of elbow room, get a big spanner on the thing and give a good hard sharp pull I can't remember the spanner size but i think it was either 18 or 22mm. You can try some WD40 on it for a day beforehand, it will not do any harm but it will stink a bit if you run the engine. The lambda sensor itself can sometimes just be cleaned with carb or brake cleaner and probably be fine to use afterwards, other people have unscrewed it and left it in a jar of vinegar overnight then cleaned it off with carb cleaner and its been like new..
    Scunthorpe
    Cheers for the reply's. It's the heater circuit within the sensor that has gone so i assume that it will still be the same. I'm not getting it from Vauxhall at £155. There is a car parts specialist in Scunthorpe and with trade discout i can get it for £40 so i think i'm just gonna change it!
    Jun 2009
    South Coast
    8 Post(s)
    Engine : POS derv
    for that price i would change it as well.. be sure its the correct type for a vauxhall those and not just a generic sensor..
  1. [Z22YH 2.2 Direct] Lambda sensor with 5 wires
    By rodzynx in forum Engine & Drivetrain
    Last Post: 10th May 2012, 22:47
  2. Lambda sensor
    By danno91 in forum Vectra C / Signum Troubleshooting
    Last Post: 26th August 2011, 16:06
  3. Lambda sensor - 3.2 V6
    By urbanfox in forum Vectra C / Signum Car Chat
    Last Post: 16th July 2010, 16:49
  4. lambda sensor again!
    By deg in forum Vectra C / Signum Car Chat
    Last Post: 5th November 2009, 23:49
  5. Lambda sensor - Z32SE - where is bank 1, sensor 1?
    By Kev_A in forum Vectra C / Signum Car Chat
    Last Post: 23rd February 2008, 14:46
how to clean a lambda sensor vectra 2.2 sri
opel signum 2.2 direct cat
vauxhall vectra 2.2 lambda sensor
vectra c lambda sensor location
where is oxygen sensor vectra c 2.2
where the lambar sensor located in a vectra 2.2 direct
how many cats does my vauxhall signum 2.2 have
vectra c 2.2 direct cat
vectra c 2.2 direct lambda sensor location
vectra c 2.2 direct o2 sensor
vectra c engine bay 2.2 lambda sensor where is it
vectra 2.2 sri lumbar sensor
vectra c 2.2 Sri 02 location
