Results 1 to 10 of 13
Thread: GSI creamy sludge in filler neck - normal?
    Regular Member coddy2200's Avatar
    doncaster
    Default GSI creamy sludge in filler neck - normal?
    Hi,
    I've got an 04 plate GSI, last year (last time I checked oil) it had a creamy sludge in filler neck, I wiped it clean.....I've just checked oil again and it's back.....is this normal.....my temp gauge always reads just above the 1/4 and never goes beyond 1/2 even when in traffic so doesn't get hot. I also never really 'boot' it if this has anything to do with it? Any advise or am I worrying over nothing (my mate has a GSi and that's the same also?)?
    Carl
    Liverpool
    sounds like the heads gone
    Regular Member PORKBALLS29's Avatar
    Epping
    I think you'll find this is common on the GSI and nothing to worry about. Does yours still have the long filler neck, if so they get a build up of condensation mixed with other stuff which causes the cream. You can take the long neck off and put the cap directly on to the block.
    Regular Member tappetpaul's Avatar
    Jan 2010
    dundee
    It's condensation in the filler neck! You can remove the plastic tube that fits like the oil cap on the cam covers and just put the oil cap in it's place! There has been a few threads on this before so have a wee search if you don't understand what I mean! Mine did this when I got it and removed the plastic neck and never seen it again!!
    Regular Member corderz's Avatar
    Bradford
    Hi mate, i also had a yellowy gunk in the filler, dont know if its normal though.....
    P.S why arent you booting it?!
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Quote Originally Posted by PORKBALLS29 View Post
    Quote Originally Posted by tappetpaul View Post
    Loads of posts about this. Remove the filler extension and see how you get on.
    I take it yours is not using water though?
    Jan 2010
    dundee
    Check your other thread in the main section answers are there
    Mileage : 000
    Yes it is normal for the 3.2V6. I take it that you have not removed the filler neck from the "top" of the engine and put the filler cap back in it,s place instead. A lot of us 3.2 v6 owners do this, then you will not have the emulsified oil collect there any more. Do a search for more information.
    Cardiff
    I have the same problem on my TT,
    its due to the long neck, and the short distant driving causing condensation and various other stuff forming at the top of the cap. this is because the engine is not getting to its optimum tempreture.
    Id say nothing to worry about, Give it a good clean and monitor it.
    Liverpool
    i stand corrected lol
  1. Take off your filler neck 3.2s!
    By Yugguy in forum Vectra C / Signum Car Chat
    Last Post: 20th December 2012, 08:47
  2. Gsi oil filler neck seal
    By larrysSRI in forum Engine & Drivetrain
    Last Post: 29th January 2012, 00:14
  3. sludge in oil filler cap!!!!!!!!!!!
    By TimTay in forum Engine & Drivetrain
    Last Post: 27th December 2010, 15:23
  4. fuel filler neck.
    By stanian in forum Vectra C / Signum Car Chat
    Last Post: 10th March 2007, 09:05
  5. Milky Oil filler neck and cap
    By neilgsi in forum Engine & Drivetrain
    Last Post: 19th January 2007, 14:55
