Results 1 to 10 of 16
Thread: (another) Rather annoying sound from boot post..
    Regular Member Jonsey's Avatar
    Oct 2010
    Walkden, Manchester
    Default (another) Rather annoying sound from boot post..
    Hello
    I have searched and looked at a numerous threads about boot rattle, and have tried the below
    repositioned boot latch
    put padding down the side of the parcel shelf supports
    checked for missing weld on C pillar
    drove without parcel shelf on
    checked for loose items in storage compartments
    checked spare wheel/well for loose items
    but I still am getting the annoying noise, its fine till I hit the 1st patch of bad road on a journey, on smooth road its fine but its driving me mad... it sounds like I have Rolf Harris in the boot playing his wobble board, with a clunk every now and then.
    Is there anything else that I can possibly check/causes
    Dave
    Sep 2010
    I had a 'chitter' from the rear of my old Vec, but it had been involved in an accident prior to my ownership, so this could be a problem?
    VIP-Member Das's Avatar
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Next time it happens touch the brakes and see if it stops. The rear pads can rattle in the carriers. I had to make up a couple of shims for my pads to stop the annoying rattle.
    Oct 2010
    Walkden, Manchester
    I will try that on the way home and report back.
    mumbles
    hi
    i had the same problem and it turned out to be the trim panel on the boot itself to test it i put my coat hanging over the shelf and then closed the boot noise gone??????????
    its worth a try
    Oct 2010
    Walkden, Manchester
    Quote Originally Posted by 37kram View Post
    hi
    its worth a try
    What side of the shelf did you put it over?
    mumbles
    hi
    i hung my jacket over the shelf so when the boot is closed it acts as a wedge between the shelf and boot
    Oct 2010
    Walkden, Manchester
    I tried the brakes & coat method on the way home from work earlier, but to no avail..
    Turdsville
    39 Post(s)
    Vehicle : Lada
    Trim : Riva
    Engine : 6.0 V12
    Year : 1954
    Mileage : 567890987
    Possibly Upper rear control arms. To check, with the car sitting on the ground put your hands in between the rear wheel arch and grab the rear of the tyre. Now pull the top of the tyre as hard as you can towards yourself rocking it back and forward. If you can hear a Knock Knock Knock the bushes on the Upper control arm are away, Do this on both sides.
    Oct 2010
    Walkden, Manchester
    Think you have hit the jackpot, just been out and tried. passenger side moves more than drivers side, and you can hear a clunk clunk as your tugging it....
    Will have to look into replacing them, hope fully that will cure it...
    Thanks your a star pal..
  1. Strange sound in the boot area
    By old cruiser in forum Vectra C / Signum Car Chat
    Last Post: 15th August 2014, 22:15
  2. How can i sound deaden the boot area to stop viberating??
    By richiem in forum Electrical & ICE (including SatNav)
    Last Post: 10th October 2011, 09:24
  3. Boot Lid Squeeking - Budgie sound...
    By Leemarksmith in forum Vectra C / Signum Car Chat
    Last Post: 3rd December 2010, 16:18
  4. Annoying sound close to windscreen
    By stryker99 in forum Bodywork & Interior
    Last Post: 24th April 2010, 04:34
  5. Post a pic of your boot build
    By Gavin2.6 in forum Electrical & ICE (including SatNav)
    Last Post: 19th April 2010, 16:55
