Results 1 to 10 of 19
Thread: Morning starts are ok - Afternoon starts are a ******!
    Feb 2011
    Uk
    Default Morning starts are ok - Afternoon starts are a ******!
    Hi - I have had trouble in starting my car in the mornings and did a check on the glow plugs - 1 was faulty so changed the lot, however, when i took a couple of them out it was plain to see that the thread was totally wrecked.
    I managed to get them in (to a fashion) but still had problems (turned out to be a faulty coolant temp switch - now replaced). Now the car starts fine in the morning but in the afternoon it has trouble starting (glow light is not coming on)...
    Any ideas what to change next? Battery? Glow plug relay? Injector seals?
    Engine : 1.9 CDTi
    Get the codes read
    Feb 2011
    Uk
    No fault lights are coming on so dont really want to take it to know-****-alls, get diddled for £70 and be no close to find out what it is
    Engine : 1.9 CDTi
    Pending codes could be stored but wont put the light on.
    If people knew where you were maybe someone local could read the codes.
    Feb 2011
    Uk
    I'm in sunny Bracknell, Berkshire
    So if anyone can help I'd be very grateful
    East Midlands
    Which engine pal,if it's a 2.0dti mine is the same,fine in the mornings but just recently it takes a couple of turns of the key to crank her up late afternoon,iv'e put it down to outside temps..eg not cold enough to trigger GPs ,but on the other hand not quite warm enough to for the car to start(between 10 to 12 degrees) temperamental i'd say.
    Feb 2011
    Uk
    Yeah tis a 2.0 dti but don't believe it's temperamental... Missus has a diesel works fine, bruv has, got 2 more fixes (glow plug relay, injector seals) then fire !!!
    Nottinghamshire
    Have a read of mine and Bigmac's threads that I've liked below about this - they might give you some ideas of some things to look to do.
    I am assuming that your car starts OK if it's been run fairly recently or if it is cold enough to preheat - i.e. it's starting when 'warm' that is causing you problems.
    http://www.vectra-c.com/forum/showthread.php?t=121174
    http://www.vectra-c.com/forum/showthread.php?t=119833
    East Midlands
    Well unlikely to be the Glow plug relay then,as your saying that it starts ok in the mornings,which is the most likely time you will see the light,alltough having said that my light has not come on the past few mornings,as the temps been around 6c.
    Also in the afternoon the glows are not needed(too warm).
    Woud'nt have thought it was the battery as you say that it starts just fine in the morn.
    I would start with the leak off pipes,change em and see what happens,not a difficult job to do.
    Feb 2011
    Uk
    Cheers guys... Not convinced its leak off or seals at it starts ok in morning when it's been sat the longest
    Hey Bigmac (if ur about) - I've read your posts and it seems like u have changed everything, I read ur last posts andit seems a starter & battery did the trick... That right ??
    I have changed plugs n sensor (for a 3rd party one) so first step is a new vx coolant temp sensor...
  1. 2.0 DTi rubbish morning starts
    By Madaxeman in forum Engine & Drivetrain
    Last Post: 22nd December 2011, 09:28
  2. And so it starts
    By chrisg in forum Vectra C / Signum Car Chat
    Last Post: 31st December 2010, 14:55
  3. cd starts from beginning
    By Phatty in forum Electrical & ICE (including SatNav)
    Last Post: 6th October 2008, 22:56
  4. It starts...
    By ClarCE in forum Vectra C / Signum Car Chat
    Last Post: 17th October 2007, 20:09
  5. Is this how it starts..
    By John35 in forum Styling
    Last Post: 30th June 2007, 08:52
car starts in the morning but not in the afternoon
