Thread: vectra 1.9 idle issue
    Feb 2011
    bedford
    Default vectra 1.9 idle issue
    hi everyone, need some help please
    i have a idling issue on vectra 54 1.9 cdti 150, i start the car from cold and the engine is very lumpy even when starting from warm it can be lumpy. it can be lumpy on idle for upto to a 30secs then it is ok. i have no fault codes or engine lights, the whole car can shake. the idle speed doesn't go up or down
    recently replaced dual mass flywheel, inlet manfold, egr valve, boost sensor cleaned.
    i've looked at all pipes and can't find any splits.
    any ideas guys will fully appreciated any ideas
    Bristol
    Vehicle : CDTI 150
    Below is a Vx Field Remedy, as yours is an early car this may be the issue.
    Field Remedy: 2056
    Subject: Engine Z19DT/L/H/J - Rough idle after cold start
    Models: Engines: Option:
    Vectra-C 2004...,Signum 2004...,Zafira-B 2005...,Astra-H 2004... Z19DTL| Z19DT| Z19DTH,Z19DTL| Z19DT| Z19DTH,Z19DTL| Z19DT| Z19DTH,Z19DT| Z19DTJ| Z19DTH| Z19DTL
    Complaint: Bad idle behaviour after cold start at low ambient temperatures.
    Cause: At low ambient temperatures a low battery voltage (<*1*>Due to low voltage the real injection quantity might not follow exactly the desired injection quantity. As soon as the battery voltage exceeds the values of 12 Volt or as the engine warms up (lower injection quantity) the idle speed quality will improve. Low voltage is caused by load response behaviour of the alternator, e.g. alternator need 1200 1/min initially in order to "start working". Once the engine was started and reved up > 1200 1/min the idle speed will stabilize w/o any cut offs. Problem might be reinforced as more electrical devices (auxiliary heater) are equipped to the system.
    Production:
    Remedy:
    In case of customer complaint please explain situation to the customer.
    Please note: There is no need to change any parts.
    FunctionalGroup: J - Engine
    Complaint Group: 21 - Poor Startability
    Trouble Code: None
    Feb 2011
    bedford
    ok i did think of 3rd injector wiring. but i had run out of ideas. thanks for your help
    Feb 2011
    bedford
    jus started the car and put a volt meter on the battery and is reading 13.5 volts. so i don't think its the issie mentioned above. after 30 odd secs within reviing, just leaving on idle the idle settles down, any chance this could be the glow plugs. thanks
    Regular Member abhinn's Avatar
    Apr 2009
    argyll
    My car was like that I changed the plugs .. added redex to the fuel tank..changed the coolant sensor and cleaned the ICV...car was still the same...next I disconnected the MAF and car was running fine ....no more erratic ideling.. 1.8 petrol..
    replaced MAF and car running great...
    Regular Member Maxim007's Avatar
    Jul 2009
    Bistrita
    Quote Originally Posted by abhinn View Post
    Your car is 1.8 (petrol)...here we talking about an 1.9 CDTI (150) diesel engine...so I think there is a different probblems...
    Jul 2009
    Bistrita
    I have the same problem on my signum 1.9 cdti...(150).
    When I start in the morning is runs OK for a couple of seconds and then is starts to ratrtle a little and there come an clicking from engine tray...
    like i say
    http://www.vectra-c.com/forum/showthread.php?t=104804
    Have you sorted the problem, robsveccycdti?
    Feb 2011
    bedford
    no not yet, i started it the other day and everything ran spot on. i haven't got a clue whats going on, sometimes it does it sometimes it don't.
    Jul 2009
    Bistrita
    Quote Originally Posted by robsveccycdti View Post
    Mine does exactly same like your`...sometimes cut off...and sometime not!
    But sience lesj Posted the reply at this thread....in couple of mornings I just trart up the car and after 2-4 sec. rev it up more than 1200 rot and my surprise was is never cut off when rev it up...
    So than what LESJ "says" is true...
    So there is nothing to be wrong....
    Thanks all...
    Please check and at your car just like I do and tell me if it cut off or no?
  1. z18xe Idle issue on cold start up
    By danno in forum Engine & Drivetrain
    Last Post: 9th March 2013, 19:40
  2. Vectra C 1.8 idle
    By damers2000 in forum Engine & Drivetrain
    Last Post: 24th July 2012, 14:13
  3. Vectra C 1.8 SRi Misfire when idle? HELP PLEASE?
    By shaine415 in forum Engine & Drivetrain
    Last Post: 25th February 2012, 15:52
  4. VECTRA SRI CDTi 150 1.9 ROUGH IDLE
    By nafmughal in forum Vectra C / Signum Troubleshooting
    Last Post: 15th January 2010, 23:23
  5. Replies: 4
    Last Post: 31st July 2008, 15:29
z19dt loud idle www.vectra-c.com
