Thread: battery light
    Feb 2011
    widnes cheshire
    confused battery light
    hi all im driving a 57 19cdti exclusive estate ive only had it for two weeks and overall im impressed with it ..nice and smooth and everything seams to be working but today after visiting a friends house when i was driving home the battery light came on and stayed on drove about ten miles anyway i stoped at the local shop before returning home and when i got back into the car and started it the light went out and hasnt been on since yet...... any clues as to a possible problem anyone ?
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Might have just been a gremlin. Do you have an electrical multimeter to test the battery and alternator? Engine off battery should be around 12.5v, engine running around 14.4v.
    Feb 2011
    widnes cheshire
    confused
    cheers dasarab
    i dont have ameter but the lads in work will have one and ill check it .it happend again today on way home from work so when i was stuck in trafic i turned engine of then restarted and the light went out again
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Steering feel ok? Usually the next sign of a failing alternator is the power steering going.
    Feb 2011
    widnes cheshire
    yea mate steering fine not noticed anything unusuall with steering ,brakes all smooth
    Oct 2006
    Waterloo, Liverpool
    12 Post(s)
    Trim : SRI NAV XP
    Engine : 1.9 CDTI 150
    Mileage : 72K
    As said, could be the alternator. Mine went on my 07 CDTI 150 last Tuesday. Battery Light on solid, and eml light. Battery charged at 11.5V when driving. Got it to the dealers just in time. Replaced under Network Q.
    Feb 2011
    widnes cheshire
    ok guys done a test with a voltage tester at work and engine off 12 v engine running 14 v
    the battery light still comes on about every other start but if i turn it off then restart it the battery light goes out ....could it be a loose conection or somthing ...duno guys any help would be great ...
    May 2007
    Norway
    Did you measure the voltage when the Battery Light was on?
    -Could be that the alternator is about to fail, but does work for on and off.....
    Easy check when you are out driving, enable the "Secret Menu"-mode in your board-computer (Hold down the Settingsbutton for 10 sec while radio is on, browse with BC-button afterwards) and you can see the battery/charge-voltage while driving.
    Feb 2011
    widnes cheshire
    ok im still getting the battery light on about every other time i start up ...ive checked the board computer whilst running with the battery light on and its showing 14 .1/2 volts drops to 12 slowly if i turn engine off ....so im thinking the alternator is ok ?.... any ideas anyone also does any one know what the other stuff is on bc display would be nice to know what the car is showing me ????
  1. Replies: 4
    Last Post: 18th August 2012, 08:58
  2. Replies: 17
    Last Post: 16th August 2012, 10:07
  3. Battery Light ON - 14.1 volts at battery
    By snapsnap in forum Electrical & ICE (including SatNav)
    Last Post: 6th December 2011, 13:55
  4. battery light on along with spanner through car light
    By conny in forum Electrical & ICE (including SatNav)
    Last Post: 24th May 2011, 13:45
  5. Battery light on, 14.4V at the battery!
    By Saulty in forum Electrical & ICE (including SatNav)
    Last Post: 16th January 2011, 23:29
