Thread: window dropped :( advice please
    Regular Member vectraturbocal's Avatar
    Aug 2010
    leeds
    Default window dropped :( advice please
    hi everyone hope your all good. my window has just dropped down as i was putting it down, its the drivers door, im guessing it will have broke the clamp on the regulator but as im not a car ,mechanic dont realy work on things like this, just wondered if it was a common fault and how easy to solve? also how does the door card come off lol? thanks everyone iun advance
    cal
    Regular Member hairy31's Avatar
    Jun 2009
    bradford
    the door card comes off .....remove ahandle then screws and if i remember correctly there at=re three screws on the bottom edge, then it just pops off......window may have just come off the hanger mate, easy to do. give me a shout if your struggling
    Jul 2009
    The Rift, Cardiff
    Take the window buttons out and disconnect, there are 3 (i think) torx screws at the very bottom of the card, pull the cover off the handle and there are 2 larger torx screw. Pull card from the bottom to pop the clips around the sides and bottom. Then gently lift the card upwards and hold it slightly away from the door, reach around to disconnect the speaker and unclip the cable from the inside handle (the one to open the door).
    You can hopefully use some mole grips as a temp fix.
    Aug 2010
    leeds
    cheers outlaw m8 will keep that in mind, thanks chrisbilly appreciated
    Aug 2010
    leeds
    sorted took about 15mins door card off, foundthe regulater had come away from door because rivits had broke so rivited it bk on and its perfect. thanks for advice
    Jun 2009
    bradford
    Thumbs up
    glad it was an easy fix mate
  1. driver's side window dropped
    By J P S in forum Vectra C / Signum Car Chat
    Last Post: 20th November 2012, 16:31
  2. Driver's window glass dropped
    By Dal5band in forum Bodywork & Interior
    Last Post: 20th March 2012, 19:19
  3. Bit of advice regarding window tinting
    By ladyvec in forum Styling
    Last Post: 20th December 2010, 14:12
  4. window chip advice
    Last Post: 2nd December 2009, 10:45
  5. Window Tinting Advice?
    By ChrisFox in forum Vectra C / Signum Car Chat
    Last Post: 5th January 2008, 19:38
