Thread: Vectra c Y22DTR fault codes
    Regular Member delboy2028's Avatar
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    Default Vectra c Y22DTR fault codes
    Hi guys well finally got my 2.2 on the road today after having the battery off for over 3 hours on charge drove it around the estate for about 20 mins and well here is the list of fault codes any help with them would be great. there is some obvious ones MAF etc.. but some i just aint got a clue.
    btw just a quick history its an auto and i got it in with a blown turbo. Car when reved starting from 100 - 1500 feels lumpy and will go into limp mode and then kick its self out again every once in a while and it wants to stall at junctions
    CIM
    B3601 - Key Capture Relay Circuit Malfunction
    (04) - Present
    B3114 - Remote-Key 1 Not Synchronized
    (00) - Not present
    ECM
    P0100 - Mass Air Flow Sensor Voltage Supply Circuit High Input
    (11) - Not present
    P0100 - Mass Or Volume Air Flow Circuit High Input
    (07) - Not present
    P0400 - Exhaust Gas Recirculation Flow Insufficient Detected
    (5A) - Not present
    P0340 - Camshaft Position Sensor Circuit Range/Performance
    (FC) - Not present
    P0335 - Crankshaft Sensor Circuit Range/Performance
    (FC) - Not present
    P1614 - Wrong Transponder Key
    (50) - Not present
    EHPS
    C1550 - Replace Electronic Control Unit (ECU)
    (37) - Not present
    U2139 - CAN-Bus No Communication with CIM (Steering Column Module)
    (00) - Not present
    BCM
    B1428 - <Unknown DTC>
    (01) - Not present
    B1448 - <Unknown DTC>
    (01) - Not present
    REC
    B0530 - Rear Left Turn Indicator Circuit Open
    (04) - Not present
    B3878 - Rear Right Brake Light Circuit Open
    (04) - Not present
    B3445 - Rear Left Brake Light Circuit Open
    (04) - Not present
    B3882 - Rear Right Tail Light Circuit Open
    (04) - Not present
    B3881 - Rear Left Tail Light Circuit Open
    (04) - Not present
    B2535 - Rear Fog Light Circuit Open
    (04) - Not present
    B2545 - Rear Left Reverse Light Circuit Open
    (04) - Not present
    B0283 - Rear Window Heater Low Voltage or Circuit Open
    (06) - Present
    DDM
    B1325 - System Voltage Low Voltage
    (03) - Not present
    B1330 - System Voltage Malfunction
    (00) - Not present
    PDM
    (03) - Not present
    (00) - Not present
    thanks in advance guys
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    B1325 is the one i find nothing on
    Full Member Big Sig's Avatar
    Its not present anyway
    Jan 2010
    grimsby
    Vehicle : vauxhall
    Trim : 150
    Engine : 1.9 cdti
    Year : 54
    am sorry to sound dumb but i erase the codes and these come back after driving 10 or so minutes yet they say not present so why do they popup?
    Barrow In Furness, Cumbria
    They will only say present while the fault is actually there. So if a sensor is only faulty for 1 second of a journey, it would only say present for 1 second and then change to not present to show the fault has occurred but isn't there at the moment.
    Best bet is to read the faults with the engine running and even while driving to try and pinpoint what happens just before each fault is flagged up.
  1. Vectra B y22dtr fuel pump interchanging codes?
    By RyanNI in forum Engine & Drivetrain
    Last Post: 22nd November 2012, 19:36
  2. fault codes vectra c turbo
    By davedave in forum Petrol Engine related
    Last Post: 29th June 2012, 13:22
  3. anyone no how to get the fault codes up on a vectra c
    Last Post: 17th May 2012, 20:04
  4. Two Fault Codes Vectra C 3.2 Auto
    By tedsy in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 15:03
  5. Vectra fault codes
    By luap2411 in forum Engine & Drivetrain
    Last Post: 23rd May 2010, 14:56
Opel B2535
B2535 rear fog light circuit open
P0340 opel 22 dtr
opel vectra c dtc not present
b2535-04 trouble code
Vauxhall DTC B2535-04
B3881-00 opel
Vauxhall DTC B2535-00
