Thread: its the top strut sleeve right???
    scotland
    Default its the top strut sleeve right???
    hi , had a knocking from front n/s for a while now , had a new drop link put in , bottom ball joint seems tight enough , when car is jacked up I can move the wheel side to side and the whole suspenion strut twists about an inch so is it the plastic bearing/sleeve ?
    also can I just undo the 3 torx on strut mount and drop it down to fit sleeve ? cheers
    Regular Member Mopar Man's Avatar
    herts
    You need to remove the strut, compress the spring with spring clamps.
    Then remove your top mount and check it.
    Before you do that check for up and down movement.
    Full Member paul.sessions's Avatar
    leighton buzzard
    i had a knocking for ages replaced everything but the mount, just to find out it was the mount..lol
    scotland
    well it turned out to be the bottom ball joint so replaced the wishbone/control arm now its solid
    now i've ended up with a brand new strut top bearing and 2 x strut top mounts surplus .
    if any you vec-c chaps are after such items please PM me as they will go on an auction site tomorrow .
    cheers
  1. spring sleeve mod
    By delberto in forum Suspension, Wheels & Brakes
    Last Post: 19th March 2011, 01:36
  2. Spring Sleeve Mod
    By deanos in forum Vectra C / Signum Car Chat
    Last Post: 6th February 2011, 22:56
