Results 1 to 10 of 17
Thread: whats causing the vibration
    Regular Member sri adi's Avatar
    Jan 2010
    ireland
    Default whats causing the vibration
    hi having a problem with my vec c i have very bad viberation coming up through thr steering colum!!! i have tried changing wheels done the track rod ends and new steering rack which was a waste of money im confussed as where this problem lies any help much appricated or has anyone had previous problem
    Does it come and go depending on speed?
    Jan 2010
    ireland
    hi its seems to be there once you hit 30mph up and it gets worse and then it can go out of it and drive perfect but its there 80percent of the time had vx wheels onit and still no joy!! and it can be der when you jump into drive and it just cums into it!! it has to be something gone/going as this was never there before this
    Jan 2010
    ireland
    bump anyone have similar problems
    Are there any noises between 20mph and 40mph?
    lincolnshire
    just an idea but DMF causes a bad vibration . can you feel a wobble through the clutch pedal as you reach biting point ??
    Sep 2009
    i u may have the same probblem as mine..... its not easily detectable, took me and my local garage long enought to figure it out on mine .
    my 1st question is ..... do the vibration/wobble get worse when u try to speed up ? when u are travelling at a steady speed u can feel the vibration/wobble as much ?
    Jan 2010
    ireland
    hi no its just viberations
    Jan 2010
    ireland
    Quote Originally Posted by crazy-dee View Post
    hi crazy-dee ya they get worse the harder you go and when you get to a steady speed 80mph it gos and it feels very lumpy on the road not running smooth
    Sep 2009
    Quote Originally Posted by sri adi View Post
    ok, im certain now that you've got the same issue i had. one of your drive shafts is going to be damaged...... as you accelorate the drive shaft moves in and out of the gear box, which is causing the viration/ wobble.... you cant tell that the drive shaft is damaged when u look at it nor does it look bent or out of shape.......the best option for you would be is to pick up a drive shaft from a scrappy for 25 30quid and replace it....
  1. What could be causing it?..
    By bigdave1701 in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2011, 21:10
  2. Could This Be What's Causing The Vibration?
    By Si-SRI in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2010, 18:24
  3. EGR causing economy problems..
    By siz1 in forum Engine & Drivetrain
    Last Post: 17th April 2010, 21:20
  4. Alternator causing DPF fault?
    By Andiman in forum Vectra C / Signum Car Chat
    Last Post: 4th October 2009, 18:34
vectra c driveshaft vibration
