Thread: Condensation at top of rear passenger window
    Liverpool
    Default Condensation at top of rear passenger window
    Has anyone else had this, I'd take a picture but it's too dark
    On the drivers side rear door, I keep getting a small section of condensation at the top left side on the seal
    Easy fix?
    Regular Member 19CDTi's Avatar
    Jul 2009
    Perth, Scotland
    thinking maybe moisture from the passenger footwell a la scuttle tray drain blocked..... mine did that until I sorted it.... wild shot but may be worth a check for 30 seconds work
    Barrow In Furness, Cumbria
    Mine does this as well. Thought it was just cos it was wet outside and the warm air in the car doesn't get to there.
    Liverpool
    its nothing to do with the scuttle pannel as that is always clear
    its only in a small section, i was thinking it could be the seal, always happens when i wash car
    Sep 2009
    Audley STAFFS
    it could well be the seal,, but I sorted my condensation problem out by taking out the rubber mats.
    Regular Member Ben Chiles's Avatar
    Feb 2011
    Redditch, West Midlands
    I have this, on both rear windows, it's just the top bit where the glass sits against the inside of the door up top. I don't have rubber mats, so can't see how that could possibly be the problem.
    I also had this happening on my astra, then i got some wind deflectors and it stopped it from happening. . . However the wind deflectors were utter crap.
    This all that's needed is to give the windows a good clean and drop the rear windows down and give the seal/padding at the top a real good dry out. That's what i'm gonna do, i also get the tiny windows at the back steam up pretty much all the time, so maybe i have moisture in the boot mannn
    Liverpool
    Quote Originally Posted by Ben Chiles View Post
    sounds like i need a good clean and an excuse to get wind deflectors lol
    i do get the boot steaming up, but i think it is mainly cause by the heat from my amp
  1. Rear passenger Window strip
    By Boobi shabang in forum Vectra C / Signum Car Chat
    Last Post: 8th January 2013, 17:20
  2. Condensation on Inside Rear Driver Side Rear Panel
    By akeem in forum Bodywork & Interior
    Last Post: 26th November 2012, 22:12
  3. Passenger Window
    By Bazz in forum Electrical & ICE (including SatNav)
    Last Post: 4th September 2011, 23:54
  4. passenger window help please
    By yadziyad in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2010, 21:57
  5. passenger window goes down on its own ??
    By tonyord in forum Bodywork & Interior
    Last Post: 2nd April 2009, 20:54
moisture in rear passenger window
im getting too much condensation in my vauxhall vectra
