Thread: Can someone tell me which gearbox i have?
    Nov 2010
    Maidstone
    Default Can someone tell me which gearbox i have?
    I have an 06 signum 1.9 cdti 150 6 speed, id like to change the fluid soon but have no idea which box it has and how much oil i need to get, can someone help?
    Regular Member neilb1's Avatar
    Feb 2011
    wigan
    i belive it is the F40 fella
    Regular Member Jezzy's Avatar
    S.E
    As above, F40, and you'll need 2.4 litres.
    Fife
    Easy way to tell, its embossed into the top of the box, look down between the engine and the battery and you will see it.
    Nov 2010
    Maidstone
    Ah thanks for that chaps, dont suppose anyone knows the grade do they?
    Jun 2009
    South Coast
    8 Post(s)
    Vehicle : Signum & Insignia
    Engine : POS derv
    castrol smx fully synthetic from halfrauds does the job mate
    Mar 2007
    GB
    Vehicle : Insignia
    Trim : SRi Nav
    Engine : CDTI158
    Year : 2012
    is it manual or automatic?
    for manual, there's no need to ever do this. Haynes don't even recommend manual transmission fluid renewal, but you can if you want to of course.
    automatic AF40 gearbox does need careful oil change at around 40k intervals
    Nov 2010
    Maidstone
    Its a manual box, so smx will do they trick?
    Macclesfield
    Vehicle : Focus
    Trim : Titanium
    Engine : 1.6 TDCI
    Year : 62
    Mileage : 9K
    Castrol smx s 75w - 85 fully synth. This oil is meant to be good.
    Regular Member PORKBALLS29's Avatar
    Epping
    That is the oil I used when I changed mine along with some molislip to help with lubrication. Very easy job to do just follow the how2 here - http://www.vectra-c.com/forum/showthread.php?t=114196
  1. M32 gearbox can`t get gear selector back in gearbox HELP!
    By v33tra in forum Engine & Drivetrain
    Last Post: 30th March 2017, 07:43
  2. Gearbox and Gearbox Oil question
    By trickydickySRI in forum Vectra C / Signum Car Chat
    Last Post: 20th September 2011, 17:01
