Thread: will disconnecting battery lose/reset my remap??
    london
    confused will disconnecting battery lose/reset my remap??
    Hi folks,
    had my DMF/clutch/CSC replaced today and the car has been running odd ever since.......just wondering if it is the remap reinstating its values and relearning or if there is a chance the map has been wiped??
    they only disconnected the battery to get to the top oft the gearbox so not sure they could've done much harm unless the alterations by the map were affected, and values have been reset to newbie.
    only mechanical works carrieds out- not tech 2 in sight so I am all flustered.
    car has been dropping into limp mode when i boot it- though becoming less frequent despite my continuing to give it stick.......
    any ideas my learned friends????
    Regular Member rushy's Avatar
    Vehicle : 9-3 Wagon
    Trim : Turbo Edition
    Engine : TID (1.9 16v)
    Year : 2010
    Mileage : 137000
    No you wont lose the map mate. I'd say its as you say just regathering values.
    Slough
    92 Post(s)
    Vehicle : insignia vxr
    Trim : vxr
    Engine : 2.8 turbo
    Year : 61
    Mileage : 38000
    would also like to know this as wanted to take the battery out to clean the under side .. khalid
    the vectra has gone , but not far away so ill still see it form time to time
    Vehicle : 9-3 Wagon
    Year : 2010
    Mileage : 137000
    What map is it mate?
    WGAF#5
    the map is stored in ecu (non volitile memory) its written to the chip
    disonnecting the battery will just cause the ecu to lose the adaptives it has already learnt ... then it will need to relearn your driving style and will take 100-150 miles to settle down again
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    No disconnecting a battery won't lose a map, remember a map is just the original settings changed.
    If you were to lose a map everytime the battery were disconnected then every car would do it, not just re-mapped ones.
    Regarding the op's question. Has everything been plugged back in when being put together?
    Regular Member Jezzy's Avatar
    S.E
    Disconnecting the battery doesn't cause the ECU to lose/wipe/change a map, any more than removing the battery from your laptop causes your computer to lose the operating system.
    Regular Member benny's Avatar
    Feb 2006
    dudley
    i would say you now have a fault ,,ie they have damaged / nocked / not refitted some thing ...
    Newport (Shropshire)
    Vehicle : Ford Kuga
    Trim : Titanium
    Engine : 2.0dtci
    Mileage : 1200
    Quote Originally Posted by happypostie View Post
    A trick that used to work for me with my old classics, was loosen the battery clamps, put a jump lead on the battery terminal, other end on clamp , both sides(+ to +, - to -), gives you a bit of wriggle room to move the battery.
    london
    cheers for all the replies. So much as i'd thought and hoped lol. Will speak to the garage in the a.m as they were closed before i made it home this evening. Done about 100 miles since i got it back and it's settling a little but will pop back to themt to get it sorted if it is still doing it tomorrow.
    Oh yea- its the eds map. Got it from regal. :-)
    And any ideas what they might of failed to connect- i'm not a tech type- i'm more a woodcarver ;-)
  1. battery off to reset remap?
    By mrk in forum Vectra C / Signum Car Chat
    Last Post: 19th March 2013, 00:03
  2. For those disconnecting battery with ESP!!!
    By rushy in forum Vectra C / Signum Car Chat
    Last Post: 30th August 2007, 22:07
  3. Disconnecting Battery
    By Neil in forum Electrical & ICE (including SatNav)
    Last Post: 21st April 2007, 18:12
  4. disconnecting the battery!
    By carl bear in forum Electrical & ICE (including SatNav)
    Last Post: 26th March 2006, 22:17
  5. Disconnecting the Battery
    By Adamant in forum Vectra C / Signum Car Chat
    Last Post: 4th December 2005, 02:41
car engine remap lost if battery disconnected
remap and weak battery
vauxhall vectra limp mode reset
if i disconnect my car battery will it lose my remap
https:www.vectra-c.comforumshowthread.php130506-will-disconnecting-battery-lose-reset-my-remap
06 vauxhall vectra ecu reset
Will resetting your ecu remove a remap
if i have a remap and disconnect the battery will i lose the remap
vauxhall vectra limp mode reset site:www.vectra-c.com
disconect battery delete remapping
if a battery goes flat on a car do i lose my remapping
remap gone after battery change
can you reset a car remap
does disconnecting battery reset remap
does it remove a remapping thing when u change your battery
ive had my corsa d vxr ecu remapped and disconnected my battery for a period of time would this affect it
will resetting my ecu loose remap
remap gone after disconnecting battery
how to reset a remmaped ecu
disconnected my car battery astra turbo
can a car lose a remap
will disconnecting battery damage radio sri 2006 vectra
reset ecu opel vectra c
will disconnecting battery reset a remap
reset vectra c unplug battery
