Thread: Clanking noise
    Jan 2008
    ireland
    Default Clanking noise
    Hi All,
    When the car gets revved in neutral and revs are brought to 1500rpm then let off and fall back down as they pass back through 1000 to 900 revs there is a clanking noise from the passenger side of the engine. When the clutch is to the floor and the same thing is done there is no noise
    Though it might be the dmf but im not too worried as the car pulls away in 1st and second with no use of the accelerator.
    its a job ill get done at a later stage.
    just wondering peoples opions. i did get a seal done on that side of the gear box recently and the drive was put back correctly so its hardly that is it?
    thanks again
    Dave
    1.9cdti sri xp sat nav 2007
    Regular Member Jezzy's Avatar
    S.E
    It's definitely the dual mass flywheel that is worn and thus making the noise. You've mentioned that the car moves in 1st without using the accelerator - that's an indicator of the clutch's health, not the DMF.
    PRESTON
    if it sounds like this, then it's the DMF.
    http://www.youtube.com/watch?v=DIfiHkUAgWc
    video from youtube, so many thanks to the original poster of that.
    Jan 2008
    ireland
    cheers chaps, two mechanics who i have spoken too were saying to leave it as it only does it intermittently. wait till it stays rattling not just at a particular rev point but then again lots of advice from all over the place!
    thanks again, and this site rocks...bought the haynes book and after looking at how easier this site's how-to on changing glow plugs i feel much better doing the work myself!!
  1. Replies: 3
    Last Post: 8th September 2012, 12:13
  2. Wheel Alignent or New Tyres? Noise Noise Noise
    By lostdog in forum Vectra C / Signum Car Chat
    Last Post: 30th March 2011, 13:29
  3. Clanking On Start-Up
    By Si-SRI in forum Engine & Drivetrain
    Last Post: 5th March 2011, 21:13
  4. Air con noise.
    By scoobs in forum Vectra C / Signum Car Chat
    Last Post: 29th June 2009, 21:36
  5. 1 noise solved (front Bearing) + 1 new noise (squeaking front brakes!!!)
    By joseantoniovalle in forum Suspension, Wheels & Brakes
    Last Post: 30th September 2006, 08:54
