Thread: Changing a 1.9 CDTi (120bhp) EGR?
    Engine : 1.9 CDTi
    Default Changing a 1.9 CDTi (120bhp) EGR?
    Is it the same procedure to change the EGR on a 120 cdti as it is on a 150cdti?
    Regular Member bangty 1's Avatar
    Sep 2010
    in a box
    id say so mate
    Regular Member zafira's Avatar
    Aug 2010
    North of Norway
    In practice yes. If you are mounting a new one and want to save it from sooting down semi blanking plate with 6 mm hole is to recommend.
    I have did it on my last zafira and my vectra and EGR has never need a clean after.
    Fife
    Here you go mate, on a Saab but it's the same engine.
    Change EGR valve on a 1.9 120
    Engine : 1.9 CDTi
    Thats great thanks
    Bristol
    Vehicle : CDTI 150
    You need a 6mm hex drive (allen bolt), make sure its not worn and that you locate it fully into the bolt head. The bolts can be very tight and the heads can round.
    Engine : 1.9 CDTi
    Is there a modded Fiat gasket for these that doesnt put the light on?
    If there is where does it go?
    lincolnshire
    Quote Originally Posted by lee gsi View Post
    the 120 EGR only has two oval gaskets and its the bottom one that needs to be blanked as the other just sends crap from the EGR back in to the process !
    Aug 2010
    North of Norway
    http://cgi.ebay.co.uk/EGR-blanking-b...item1c195252c9
    This plate can be used, mounted between the pipe from the exhaust and egr. You just need to drill a 6 mm hole in it, or else the eml will come up. You can make the plate of 1-2 mm steelplate. I did that, works fine. You need two gasket, one in both side of of the plate, or you can use one gasget and exhaust pasta on one side.
  1. 1.9 CDTI 120bhp
    By loopy_kiwi in forum Diesel Engine related
    Last Post: 13th April 2012, 19:33
  2. i want a cdti 120bhp tuning box
    By 0114NIGEL0114 in forum Tuning
    Last Post: 8th June 2011, 14:05
  3. Cdti 120bhp air filter help
    Last Post: 7th May 2011, 18:30
  4. breeze 1.9 cdti 120bhp
    By chay6684 in forum Vectra C / Signum Car Chat
    Last Post: 21st February 2011, 18:48
  5. 1.9 cdti 120bhp, cooked !!!
    By sthomson1 in forum Engine & Drivetrain
    Last Post: 27th February 2009, 14:53
