Results 1 to 10 of 11
Thread: CDTI 150 Thermostat
    Regular Member lee1828's Avatar
    Jan 2010
    stockton on tees
    Default CDTI 150 Thermostat
    Decided to change my thermostat today due to my temperature gauge struggling to get over 70, with the heaters on would drop to the bottom of the gauge!
    Before changing it i decided to fit the new temp sender from the new housing into the old housing still on the car, my heaters have always warmed up quickly and get red hot and my car has always been great on fuel, didnt even notice a massive difference during the colder weather we have had.
    Anyway i took the car for a half hour run with heaters on number 2, to my surprise the temp gauge hit 85 and didnt move!
    I decided to fit the new stat anyway and on checking the old one once removed, the stat was closed as it should have been!
    Baffled!
    Administrator plasma's Avatar
    On the Forum
    359 Post(s)
    Engine : 150
    Mileage : 74000
    I think they get lazy rather than stuck open... or open too soon...
    Jan 2010
    stockton on tees
    The bit i dont get is that changing the temp sender unit shouldnt have made any difference if the stat was knackered or lazy but it did!
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Sounds like your temp sender unit was faulty and thus giving you dodgy readings.
    Regular Member chrisknights's Avatar
    Feb 2011
    brighton
    how long did it take to change over as come payday im going to do mine , as was it a easy job
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Quote Originally Posted by lee1828 View Post
    I changed the stat on my 2.2DTI before xmas, and although the cab does heat up quicker than before the needle only moves when I turn the heating down (it hardly used to before). So I'm next going to change the temp sensor just to see if it changes how the needle reacts. Let you know my outcome.
    Jan 2010
    stockton on tees
    Quote Originally Posted by chrisknights View Post
    To change the stat took me around 40mins, its a little awkward but you will be fine if you take your time. I didnt remove the glow plug relay which has been advised, i didnt have any issues getting the stat off with the relay in place..
    Jan 2010
    stockton on tees
    Quote Originally Posted by si_hoss View Post
    well mine had all the symptoms that everyone else was having, i wasnt convinced it was the stat, hence changing the temp sender first, my car stayed at 80 - 85 with the heaters on without the new stat. My old stat was closed when i checked it which is correct..
    Regular Member RobW's Avatar
    Tain - Easter Ross
    Give an hour for changing it and follow the how2 on here to the letter.
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Don't look at it in a waste of money but the stat for the CDTI 150 was upgraded to make it more reliable.
    Gazza4
  1. thermostat 1.9 cdti 120 and 150 is it the same?
    By grabos in forum Engine & Drivetrain
    Last Post: 7th January 2013, 17:35
  2. 1.9 CDTI 8v THERMOSTAT
    By GSiSnash in forum Engine & Drivetrain
    Last Post: 7th September 2012, 19:17
  3. 1.9 cdti 120 Thermostat Mod
    By no1vic in forum Engine & Drivetrain
    Last Post: 20th February 2011, 21:43
  4. 1.9 CDTI thermostat
    By Ginge7289 in forum Engine & Drivetrain
    Last Post: 27th January 2011, 07:07
  5. 1.9 cdti thermostat
    By ruby2009 in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2010, 17:51
