Thread: Rear door electrics
    London
    Default Rear door electrics
    Hi,
    I have searched but couldn't find a similar problem so here goes. On my pre facelift Vectra the red light on the door when you open it will no longer comes on and also when the door is open it does not register on the dashboard. I have no idea where to start to find the problem so any advice would be appreciated.
    Another thing I have noticed is that the interior alarm sensors don't work when I lock the car the LED just flashes, Don't know if this would be related.
    PS its the rear door on the drivers side.
    Thank you
    John
    Regular Member si_hoss's Avatar
    Apr 2009
    Stevenage, Herts
    Does the interior light come on? I would say it sounds like the switch on that door is stuck, not sure where it is actually as never looked. If you find it give it some WD-40 and a good loosening up!
    London
    hi, thanks for the quick reply.
    The interior light does not come on when that door is open. I will have a look around the door to see if I can find a switch.
    Ely, Cambridgeshire
    61 Post(s)
    Vehicle : Insignia Tourer
    Engine : 2.0 CDTI (160ps)
    Year : 2010
    The switch is built into the lock mechanism on Vec-C's. It will probably need the lock mechanism changing/replacing on that door.
    London
    thanks for the reply,
    do you know if its a big job?
    Ely, Cambridgeshire
    61 Post(s)
    Year : 2010
    Not the easiest job in the world, but not too terrible.
    Jul 2009
    The Rift, Cardiff
    Try re-seating the large blue plug between the door and pillar.
    Apr 2009
    Stevenage, Herts
    My Golf Mk4 had a similar problem, the central locking was playing up and the light wouldn't come on on the one door. I looked into it and the common fix was to re-solder the joints on the microswitches in the lock setup. Not saying the Vec has the same setup, but if that kinda thing works would cost nothing compared to a new locking mech.
    London
    thanks for all your advise, I have this afternoon off so I will have a good look at it
    Full Member paul.sessions's Avatar
    leighton buzzard
    i took one off a spare door i had the other day to find out (i had the same prob). i wanted to see how it worked i wrecked the lock mechanism trying to open it but there is a tiny microswitch inside the sealed unit, so i tried triflow similar to wd40 in the car door that was playing up it worked for a few days then came back on. so then i sprayed switch cleaner into the lock about half a can. and its been off a couple of weeks so far. fingers crossed! it stays that way. spray into the lock at 45 degrees downwards thats where abouts the switch is situated..
  1. drivers door electrics dead!
    By pugs,signum in forum Electrical & ICE (including SatNav)
    Last Post: 27th January 2012, 14:47
  2. Passenger door window and mirror electrics not working. Any ideas, thanks.
    By MT82LFC in forum Electrical & ICE (including SatNav)
    Last Post: 7th May 2011, 01:09
  3. Rear Electrics
    By steve in forum Electrical & ICE (including SatNav)
    Last Post: 5th March 2011, 16:27
  4. Drivers door electrics playing up
    By hefilump in forum Electrical & ICE (including SatNav)
    Last Post: 12th April 2010, 12:52
  5. rear electrics
    By scottyd in forum Vectra C / Signum Car Chat
    Last Post: 21st April 2009, 18:45
vectra c rear door micro switch
