Thread: Blocked breather? and excessive oil in plenum. 3.2 v6
    Regular Member Chuddy's Avatar
    Jul 2009
    Derbyshire
    Vehicle : 3.2 gsi
    Trim : gsi
    Engine : 3200
    Default Blocked breather? and excessive oil in plenum. 3.2 v6
    After elimating headgasket failure as te cause for excessive white smoke i checked my breather pipe to see if it was blocked, which im not 100% certain but i think it is... Reason being that i could only really get to one end of it without the need to remove alot of things but it was deffinately gunged up and when i started the engine there was slight smoke coming through the breather on the intake end. Shall i have this replaced?
    After checking the breather i thought id check the plenum as i know i have a fairly bad oil leak from what seems to rocker and from what ive been told. Upon removing the cover the plenum had an very thick build up of dried up oil and a bit of wet. Is this cause for concern?
    Cheers guys
    Regular Member Jezzy's Avatar
    S.E
    On all of the GM V6's (2.5, 2.6, 3.0 & 3.2) blocked breathers are a common problem and the increase in pressure they create causes the rocker cover gaskets to fail.
    On the V6s as installed in the Omega (i.e. longitudinally) there isn't just one breather pipe, there are several components, so when you say you've checked THE breather pipe, you may be missing some bits out.
    Jul 2009
    Derbyshire
    Vehicle : 3.2 gsi
    Trim : gsi
    Engine : 3200
    Cheers pal
    Anyone have diagrams to where the full system leads etc then? or info? as bit of a pain to even get to the other end of the pipe that goes along the front
    S.E
    This is how to clean the breathers on the Omega's V6s. Not sure how much use it is to you though, as most of it involves the plenum - which is the item most different on the longitudinally and transverse mounted versions of the V6s. Have a read anyway.
    http://www.omegaowners.com/forum/YaBB.pl?num=1285583967
    Jul 2009
    Derbyshire
    Vehicle : 3.2 gsi
    Trim : gsi
    Engine : 3200
    Cheers for that mate but unfortunately i actually saw that guide earlier and you're right they are too different. Gonna have my sisters fella whos a mechanic have a look at it and let me know for future reference
    Regular Member Harro's Avatar
    Jan 2008
    York
    Same here, signs of oil leaking round the cam covers. Car's 8 years old and getting on to 80K miles, so due for new spark plugs. Gonna have a go at fitting new gaskets and unblocking breathers at the same time. Looks like an involving job, so would probably cost a bit at a garage?
    Jul 2009
    Derbyshire
    Vehicle : 3.2 gsi
    Trim : gsi
    Engine : 3200
    Quote Originally Posted by Harro View Post
    My local garage i normally use said it'd prob take 3-4hour but im gonna try get my sisters fella to have a crack at it for me lol as im too much a novice for a engine such as the v6. Air filter replacement is about the most i dare to do lol
    Sep 2010
    worcester
    unblocked my breather this afternoon after finding it blocked with gunk... are you talking about the one with the nylon cover over it sits just under by oil filler cap? its not too bad a job if you slide the expansion tank off its mountings you can see where pipe goes i took it off and blew degreaser thro it with air line/degreaser cleaned out a treat also took offoil filler neck that always gets gunked up just replce cap in its place... plugs are not as hard as they say to change if you fancy having a go took me 35 mins to change all of them was quoted 2 hrs labour at dealers..any problems gimme a shout
  1. plenum removal
    By fiend61 in forum Vectra C / Signum Car Chat
    Last Post: 12th February 2012, 11:13
  2. Advice sought - plenum/oil cooler on 3.2V6
    By MysteryElite in forum Engine & Drivetrain
    Last Post: 29th November 2011, 20:12
  3. Plenum Chamber Removal Z32 v6
    By CDUB in forum Vectra C / Signum Car Chat
    Last Post: 24th September 2008, 17:19
vectra 3.2 engine breather
vectra c 3.0 breather
vectra c 3.2 breather pipes
how to remove plenum vectra zc 3.2
vauxhall vectra 3.2 v6 2002 breather
vauxhall vectra 3.2 v6 transverse engine diagram
vectra omega plenum
