Thread: Anyone changed a 2.0 / 2.2dti turbo before?
    Regular Member Innes's Avatar
    Plymouth
    Default Anyone changed a 2.0 / 2.2dti turbo before?
    I think my turbo casing is leaking oil into the actual turbo as I have been getting through oil and have noticed plenty of fresh oil leaking out the edge of the inter cooler hose. The car is going in for its MOT on Thursday so I have also asked the garage to have a look at the turbo as well and let me know if my diagnosis is correct. In the meantime I thought i'd ask if anyone on here has changed a 2.0 or 2.2dti turbo before? Its looks pretty accessible as its at the top of the engine and to the rear with plenty of space around it. To me it looks like it just bolts on!
    The Haynes manual says the exhaust manifold has to come off first which it gives it a 4* rating which I'm not really happy about giving a go but to actually remove and replace the turbo gives it a 3* which is more within my ability. As we know the HAYNES can over complicate things and tell you to remove things first when actually you don't need to (door lock and air recirculating motor spring to mind).
    So would I need to remove the exhaust manifold or is Haynes being over cautious again? Is this something I should tackle or leave to the garage? The only reason I'm contiplating doing this myself is that the bank account is extremely empty at the moment!
    Plymouth
    Any one???
    Full Member Caveman_nige's Avatar
    Jun 2009
    South Coast
    Vehicle : Vectra and a Signum
    Engine : Z18XE,Z19DTH,Z20NET
    sounds like its in the same place as my turbo... its not that hard to, just fiddly.. I unbolted mine from the exhaust manifold but one of the studs sheared so then had to remove the manifold and take it to a bloke that removes snapped studs. I found a bloke who did it very quickly for £30 i think.. He put in a new stud and problem solved.. That was the only issue and quite a common one it seems.. If you wish to replace the turbo you will need to remove it from the exhaust manifold anyway..
    Plymouth
    Yes the 2.0dti uses the same turbo as the 2.2 and is in the same position. So I don't need to remove the actual exhaust manifold? The turbo is just bolted on?
    Jun 2009
    South Coast
    mine is a different engine but from what i have seen of your block in the manual it looks like its in a easier position than mine was.. i would say that you should just unbolt the turbo from the manifold. i think the manual says to remove the turbo from the manifold if 'needed' meaning they are working on a complete engine strip down but you only want the turbo off.....
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    Quote Originally Posted by Innes View Post
    I don't believe so. The 2.2 turbo is a variable vane one, the 2.0 isn't I don't think.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Plymouth
    had it in for its MOT and asked the garage to look at the turbo and they said its fine. What a relief but its still a mystery why I'm getting through oil!
  1. 2.2Dti turbo gone
    By jono_c in forum Engine & Drivetrain
    Last Post: 29th August 2012, 10:09
  2. Changed 2.2DTi aux belt
    By Mogsy007 in forum Vectra C / Signum Car Chat
    Last Post: 21st October 2010, 20:08
  3. Squeaky turbo on 2.2dti
    By dnl_303 in forum Engine & Drivetrain
    Last Post: 5th October 2009, 19:17
  4. Someone Help!!! 2.2dti Turbo......
    By chairman_miaow in forum Engine & Drivetrain
    Last Post: 30th December 2008, 15:42
  5. is it possible to change 2.0 dti turbo to 2.2dti turbo
    By EURO G in forum Engine & Drivetrain
    Last Post: 22nd October 2008, 07:35
