Thread: CDTI 120 startup issue
    PRESTON
    Default CDTI 120 startup issue
    A friend has a 120 cdti Vectra which has an occaisional starting issue. Most times his car starts normally but on occaision he turns the key and it goes click, nothing. He has had the DMF, clutch and starter changed recently, but the starting issue was there before this. He was advised it was the CIM, which he had changed and still the problem persists. There are no MIL warning lights, so no codes to give an indication of the problem, any ideas guys, i'm stumped!!!!
    Regular Member Mopar Man's Avatar
    herts
    Starter motor.
    PRESTON
    Starter motor was changed with clutch (only last week) as it was suspected to be this in the first place. The issue is excately the same with a new starter.
    Regular Member chrisknights's Avatar
    Feb 2011
    brighton
    Quote Originally Posted by barney490 View Post
    might be worth checker if there is a fault in the earth wire to the starter
  1. SRI CDTI 150 Blue smoke on startup
    By sukyb in forum Engine & Drivetrain
    Last Post: 15th February 2011, 13:47
  2. SRI CDTI Blue smoke on startup
    Last Post: 8th February 2011, 12:01
  3. Blue Smoke on Startup SRi CDTI 16v Help !
    By Tim in forum Engine & Drivetrain
    Last Post: 22nd December 2009, 19:09
  4. CDTi 150 issue... Please help !
    By Billy110 in forum Engine & Drivetrain
    Last Post: 3rd July 2009, 11:56
  5. new cdti issue!!
    By ronnie63 in forum Engine & Drivetrain
    Last Post: 4th May 2009, 09:50
