Thread: Air Box Mod
    Fife
    Default Air Box Mod
    Well done the airbox mod at the weekend, only difference iv noticed is a high pitch sound coming from it in the high rev range this normal? or should i have cause for concern?
    Regular Member Exclusive BV's Avatar
    West Midlands
    As long as you only removed the part in the bottom half of the airbox it should be fine.
    Might be worth a check to make sure that all the hoses going to the airbox and the jubilee clip are secure.
    Fife
    Quote Originally Posted by Exclusive BV View Post
    Yeah only removed the bottom part, i'll give it another look when i get the chance. thats prob the reason they have that funnel there 2 stop the noise
    Regular Member triple595's Avatar
    Mar 2011
    llandrindod wells
    are there any pics for this mod?
    6 Post(s)
    Quote Originally Posted by triple595 View Post
    Pretty sure there is. Have you tried using the search function to see?
    Sodding Typical on Sea
    Pics are in the How2 section pretty sure. under "Air box mod"
    Have to say I have never heard of any adverse noise or affect on any of the posts, especially the sound you describe, sorry to hear it wasn't a total success so far.
    Sep 2009
    Glasgow
    after mine the turbo was slightly louder.
    Regular Member John C S's Avatar
    May 2007
    Gangsta crossover on the drive? Check
    Lazy Blighters!
    It's in the HOW2 section and there's the index to make it simpler.
    It's there for 1.8VVTi, 1.9CDTi and the 3.0V6, but all engines pretty much have identical airboxes!
    LINKY
    Mar 2011
    llandrindod wells
    Cheers new to the site so still getting used to the layout, found it now, thanx
    Sep 2010
    doncaster
    hi mate, iv dun the air box mod and fitted a k&n filter so getting alot more air throw the box now, iv got the same noise, was told its the turbo winding up note to worry about, but im going to check the pipes just in case of a air leak
