Results 1 to 10 of 26
Thread: factory fit sat nav
    New Member jimmi's Avatar
    Feb 2011
    mirfield
    Default factory fit sat nav
    hi guys hope you can help,
    I'm wondering if its possible to fit a vx built in sat nav to my sri. its got a cd30 radio and normal display. What would i need to upgrade to the built in unit and how long would it take to fit?
    cheers james
    Wirral / ellesmere port
    10 Post(s)
    Vehicle : insignia tourer
    Trim : elite
    Engine : 2.0 cdti 160
    Year : 2011
    hi m8
    you need the cd70,cid,rgb cable and a nav aerial from ebay,not sure wot
    there called but only cost 10 pound ) make sure you buy them both together
    already paired then all you need to do is remove your cd30 and
    display and fit ya cd70 and cid in and it will work no problem.
    doing the above will take no more than 10 mins to swap over
    the only time when you have problems is if you buy the cd70 and cid
    seperately as they wont be programmed to each other.
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    This is a mod I'm looking to do, from my CCR2006 with GID, to a CD70 with CID
    Regular Member kenp's Avatar
    Kr. Hyllinge, Denmark
    Engine : 2.2 Direct
    Quote Originally Posted by tony-1977 View Post
    Then you are out in a bit of rewiring.. along with new cim (if you want steering wheel controls) and new heater panel if you have ECC....
    Oct 2009
    UK
    Vehicle : z
    Trim : z
    Engine : z
    Year : z
    Quote Originally Posted by kenp View Post
    I'm not too fussed about the steering wheel controls, and don't have ECC (pre-face SRi model), so that shouldn't be a problem. I guess it will work of the stalk controls like the CCR2006 I have does?
    Engine : 2.2 Direct
    Nope.
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    can i put a cid with my ncdc 2013 if so what do i need
    Full Member Robsey's Avatar
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    Quote Originally Posted by paulvectrac View Post
    You will need the correct Half CAN Colour Display.
    (Not a full CAN display)
    You will need to add additional colour display wires and the second small connector that is only used for the colour display.
    Monochrome GID has onlyone rear socket.
    Then the correct programming to pair everything up.
    morecambe
    43 Post(s)
    Vehicle : vectra
    Trim : vxr
    ok mate how ment wires di i need to add is there any to the odb
    North East Cheshire
    22 Post(s)
    Trim : Energy
    Mileage : 131,000
    The stalk is only for Half CAN vehicles.
    If you don't have scroller controls - then all functions can be easily operated via the radio facia.
    That is all I do... wife's has no controls yet.
    You will need to get a whole rack of components
    1) CD 70 and Display
    2) Fakra sat nav aerial from fleabay
    3) SOT122s or ISO2CAR conversion lead (converts ISO to Quadlock)
    4) If you have an 18 pin connector on your display, then you need to get a 32 pin connector.
    5) Rewire the screen connector per Bigmac's How 2 (TID to GID)
    6) Then you will need to swap the power wires round on the display plug
    7) If you are fitting a CID, then you will need the RGB cable.
    8) You will need an aerial converter plug - convert to Fakra from original Vx plug.
  1. UHP Factory Bluetooth
    By millard2004 in forum Electrical & ICE (including SatNav)
    Last Post: 21st October 2012, 22:02
  2. Factory amp???
    By Jonsey in forum Electrical & ICE (including SatNav)
    Last Post: 18th January 2012, 12:43
  3. Factory looking DRL
    By lee gsi in forum Styling
    Last Post: 15th September 2011, 21:40
  4. Factory Fit Alarm
    By Redviper in forum Electrical & ICE (including SatNav)
    Last Post: 5th January 2010, 13:01
  5. Notification from the Factory.......
    By david.aka.judas in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2007, 07:33
how to fit a sat nav in to a vectra c
