Thread: Injector replacement party with the V6CDTi
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Thumbs up Injector replacement party with the V6CDTi
    Set about replacing the injectors of my car on Saturday Pardon my faulty lights and brake-pad light
    This is a cold start with old injectors on day D
    http://www.youtube.com/watch?v=Dq0M0Lp6Y4U
    After 4hours of screwing around all 6 injectors were out and replaced with new ones. This is the immediate result. Starts up funny
    http://www.youtube.com/watch?v=HdrMgVv1iWk
    This however, is a proper cold start with the new injectors. I think it sounds much better.
    http://www.youtube.com/watch?v=M1pKpi3G9U4
    I have to say that the engine runs much better under acceleration and only smokes a bit when close to redline (in 3rd gear only ). I'm a happy bunny now Fuel consumption has also improved, whereas power remains unchanged
    This is definitely something I recommend to anyone who can source injectors for a good price, otherwise just forget it...these are 750€ a pop from a dealer
    Sep 2010
    Right here, right now.
    6 Post(s)
    Trim : SRI
    Engine : 3.0 V6 CDTI
    You got a part number Celes? Are they the same for the Y30DT and the Z30DT?
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by lee_umney View Post
    I've 18 injectors for the Y30DT at home (6 bad, 6 unknown, and 6 good-ish) but unfortunately they won't fit the Z30DT.
    Jan 2006
    Dalriada
    Sounds alot better mate - good work
    Northampton
    Engine : A20DTH
    Mileage : 88000
    Did you have to Tech 2 the injectors in?
    Did you try an injector cleaning additive first before you changed the injectors?
    Seems a bit strange they should all need replacing at once.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by merikiito View Post
    Didn't need to use Tech2 to make the new injectors work
    Tried various additives and none helped with the slight smoke issue...and anyway the old injectors weren't all that bad I replaced all 6 only because I got a bargain...450€ for the lot...brand new Wouldn't have touched them otherwise
    Northampton
    Engine : A20DTH
    Mileage : 88000
    I thought you had to tech 2 new injectors in as the way they are made means they all have different fuel flows. There should be an ident number or something which tells you the flow value which is then programmed into the car.
    By not doing this it could cause damage to the car and poor fuelling/performance.
    Slovenia, Koper
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    There are some numbers on injectors M4 M25 M13 M12 etc. (old ones were L), but I was told by the dealer it won't matter. The 1.9CDTi does need them coded though.
  1. injector replacement
    By smartalec0310 in forum Vectra C / Signum Car Chat
    Last Post: 14th November 2012, 18:35
  2. Replies: 8
    Last Post: 31st August 2012, 22:19
  3. Injector Seal Replacement
    By siz1 in forum Engine & Drivetrain
    Last Post: 24th March 2011, 10:53
  4. Denso specialist for injector refurb - V6CDTi Y30DT
    By Celes in forum Engine & Drivetrain
    Last Post: 15th November 2010, 08:50
  5. Done the 3rd Injector plug replacement....
    By Dan_BlackSRi in forum Diesel Engine related
    Last Post: 3rd March 2009, 17:52
