Thread: fog light fitting
    Regular Member johnny ni's Avatar
    Oct 2010
    n. ireland
    Default fog light fitting
    hi guys
    was thinking about fitting front fogs to the car- its a 2006 prefacelift vectra 1.9cdti design
    i was just wondering is the wiring already there ie. is it just a plug in job or will it have to be wired in direct??
    also can i get a vauxhall genuine front fog switch for inside
    any help appreciated
    johnny
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    99.9% chance the wiring is not there. And its not just as simple as plugging it in either.
    If you want it to look completely factory you will need to check you have the correct UEC(fusebox) and you will also need a Tech2 session at your local dealers. If you dont have the correct UEC you will need to change it.
    I retrofitted front foglights to my preface. I got the lights and the wiring and just connected them in the old fashioned way using a relay and a small illuminated rocker switch fitted into one of the blank switch spaces on the dashboard.
    To check and see if you have the wiring pop the bonnet and down the inside of the bumper, right in the middle you will see the outside temperature sender unit and the wiring to it coming from the NS of the car. If the wiring goes to the OF of the car chances are you have the wiring, if it doesnt you dont.
    Oct 2010
    n. ireland
    excellent reply there das arab
    thats all the info i needed thank you so much
    didnt think it was going to be as easy as plug in and away i go!!
    any recommendations as to where to get a nice set of lights and surrounds??????
    VIP-Member
    40 Post(s)
    Vehicle : `
    Trim : `
    Engine : `
    Year : `
    Mileage : `
    Ebay, as usual, is your best friend, that's where I got mine, lights loom and grills all in a oner. Post a pic of your bumper and hopefully others will be able to suggest the correct lights.
    Oct 2010
    n. ireland
    will get the camera out tomorrow
    thanks again for the advice buddy
  1. Help with fog light fitting.
    By stuart813 in forum Electrical & ICE (including SatNav)
    Last Post: 1st January 2011, 19:27
  2. Fitting xenon light kit .
    By spandy234 in forum Vectra C / Signum Car Chat
    Last Post: 28th October 2010, 21:43
  3. Fog Light fitting
    By magpie27 in forum Electrical & ICE (including SatNav)
    Last Post: 30th April 2009, 22:32
  4. fitting signum fog light surrounds..
    By PAULMAC77 in forum Styling
    Last Post: 25th March 2009, 20:47
  5. Fitting rear light
    By Padster72 in forum Vectra C / Signum Car Chat
    Last Post: 3rd May 2008, 08:36
