Results 1 to 10 of 17
Thread: help dreaded limp mode
    Feb 2011
    lisburn
    Default help dreaded limp mode
    Hi all, my 04 3.0cdti vectra has put the eml light on and gone into limp mode I have carried out the pedal trick and the code is 0105 any ideas
    Feb 2011
    lisburn
    disconnected battery to clear ecu light out car drives ok until u give it the welly then eml back on and still flashing the 0105 code.
    Feb 2011
    lisburn
    Oh and it is the y30dt engine
    Leeds
    P0105 - Boost Pressure Sensor Circuit Range/Performance
    Just found this on the net and it seems this could be the problem
    Leeds
    Quote Originally Posted by irmscher-brett View Post
    Proper fault code definitions are here: Vectra-C Y 30 DT,
    P0105
    -03 Boost Pressure Sensor Circuit Low Input
    -07 Boost Pressure Sensor Circuit High Input
    -52 Boost Pressure Sensor Circuit Range/Performance
    Feb 2011
    lisburn
    could the sensor just need cleaning
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Try that first and check for split boost hoses
    Feb 2011
    lisburn
    Is it hard to get at the sensor
    Leeds
    Quote Originally Posted by iwtand View Post
    no its usually 1 bolt. Not sure where it is on yours, but I have a 2.2 dti sri and its located at the top of the engine block on mine infront of the turbo and to the right. took me 2 minutes to clean it with carb cleaner. Can't find the thread on my page, but if you look in the 'HOW 2 SECTION' u will probably find it
    Feb 2011
    lisburn
    anyone know location on y30dt engine
  1. Vec C 2.2 DTi going into limp mode
    By krazylegz in forum Engine & Drivetrain
    Last Post: 21st February 2012, 20:02
  2. Limp mode!!! HELP
    By J's Turbo in forum Engine & Drivetrain
    Last Post: 14th October 2011, 15:06
  3. Limp mode or dead mode
    By JSYSH466Y in forum Engine & Drivetrain
    Last Post: 2nd July 2009, 09:46
  4. Limp mode
    By dan1983 in forum Vectra C / Signum Car Chat
    Last Post: 3rd July 2008, 18:35
  5. Dreaded limp home mode
    By wickedwillie in forum Vectra C / Signum Car Chat
    Last Post: 25th February 2008, 13:23
