Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: brake rewind piston tool details
    Full Member paul.sessions's Avatar
    leighton buzzard
    Default brake rewind piston tool details
    can someone with one of these supply me with some details what is the dimensions,the diameter of the disk, the diameter of the pins and the distance apart they are please.. going to make one at work. thanks Paul
    May 2008
    Tyneside
    Here goes, disc 32mm overall diameter, pins 5.5mm diameter at 19mm centres. Thats the dimensions of the disc in a sealy set I have. HTH
    Wales, UK
    I purchased a draper one from Halfords. Few mm out, so filed the notches down, worked a treat lol
    Regular Member vxpenfold's Avatar
    Nov 2010
    sittingbourne,kent
    Vehicle : Vectra Hatchback
    Trim : Life(well it was)
    Mileage : 166000
    yh i got the one from halfords, a few mins with a bench griner and file and fits a treat, better than the snapon ones actually
    Regular Member rushy's Avatar
    Vehicle : SRi
    Engine : Z22SE (2.2 Petrol)
    Mileage : 137000
    Paul, I've lent mine out. If you want when I get it back I could post you the adapter that fits the Halfords one, it weighs nothing so easy to post. It uses a 1/4 inch drive off the top of my head. TBH I recon the adapter would be a good item for the club shop.
    VIP-Member GSiFan's Avatar
    Houghton Regis, Bedfordshire
    17 Post(s)
    Vehicle : Vectra GSi 3.2 V6
    Trim : GSi
    Engine : Z32SE
    Mileage : 212,060
    Here you go...
    In its packet...
    On the kitchen worktop...
    Oblique angle...
    Note the shape.
    The tool overall diameter is 41.0 mm. Pin diameter is 6.0 mm. Distance between outside edges of pins is 37.8 mm, inside edges 26.0 mm. The depth of the recess in the 'cup' is 2.8 mm. The pins protrude above the top edge of the 'cup' by 1.0 mm. All measured with my vernier calipers.
    If you want to borrow the tool, I work near St. Albans. Let me know.
    EDIT - What have I got then?
    Paul
    2003 Vauxhall Vectra GSi 3.2 V6
    Chelmsford
    Quote Originally Posted by mark_647 View Post
    Same here, easypeasy, no need to get the adaptor
    Vehicle : SRi
    Mileage : 137000
    Quote Originally Posted by GSiFan View Post
    Here you go...
    In its packet...
    Oblique angle...
    Note the shape.
    Paul
    Arr, I have the Lazer tool, but I bought my adapter from the bay, yours is the real one, mine looks like its been manufactured after market if you get my drift.
    Chelmsford
    I must admire the effort that GSIfan has gone to with the photos!
    May 2008
    Tyneside
    Quote Originally Posted by tridley View Post
    This adaptor is for a 1.8 with solid discs, looks like the 3.2 V6 is different.
  1. Brake piston/rewind tool
    By 123rado in forum Suspension, Wheels & Brakes
    Last Post: 26th December 2012, 12:04
  2. piston rewind tool
    By brtsam1 in forum Vectra C / Signum Car Chat
    Last Post: 7th February 2012, 20:39
  3. Piston Rewind Tool
    By Jamesx81x in forum Suspension, Wheels & Brakes
    Last Post: 9th January 2012, 13:07
  4. Brake Piston Rewind Tool - Which One?
    By sophos9 in forum Vectra C / Signum Car Chat
    Last Post: 12th March 2011, 19:17
  5. Piston Rewind tool
    By eaglepva in forum Vectra C / Signum Car Chat
    Last Post: 11th March 2010, 10:58
2003 vectra brake rewind tool
