Thread: coolant change
    South London
    Angry coolant change
    Tried changing the coolant on my 2.2Dti vectra.
    Removed the undertray and to gain access to the drain tap I had to remove
    the lower radiator support, supporting the radiator with a small wooden wedge. All required now is to turn the radiator tap and let the coolant flow out. The tap only turns 90degrees but then nothing, not a drop came out.
    Pushing/pulling getting annoyed with the tap but still not a drop came out.
    Am I missing something, has anyone else drained their coolant in this way.
    Please let me know.
    Glasgow
    I would have just taken the bottom hose off the radiator.
    Wirral
    Engine : 1.9CDTi
    Mileage : Lots
    As above, just take the bottom hose off and don't let it go up your sleeve if it's cold! Not a nice feeling.
    Jul 2009
    The Rift, Cardiff
    My tap took quite a few turns before it started to flow. I had to use open pliers to help turn it.
    Regular Member jimmyred's Avatar
    Dec 2010
    Southport
    my drain tap turns through 180 degrees. It can be stiff, you should feel it rising in its mount as you turn it, its a fairly steep screw i think. I have a 1.8 though but they are prob the same? Perhaps some one can confirm this?
  1. Coolant change
    By jamiedvvt in forum Vectra C / Signum Car Chat
    Last Post: 17th January 2013, 10:58
  2. coolant change
    By nick6515 in forum Engine & Drivetrain
    Last Post: 24th November 2012, 15:38
  3. Coolant change
    By Corey in forum Troubleshooting
    Last Post: 14th October 2012, 21:26
  4. Coolant Change
    By macdad in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 23:21
  5. Coolant change 2.0T?
    By mark1319 in forum Engine & Drivetrain
    Last Post: 19th December 2008, 01:28
coolant flow 1.9cdti
