Thread: Thrust bearing noise
    Regular Member robengland9's Avatar
    Feb 2011
    london
    Default Thrust bearing noise
    I was getting a noise from thrust bearing today when pressing clutch pedal so if that needs changing then best do clutch and pressure plate at same time as car has high miliage ....I might wait for better weather to tackle the job.... unless it breaks down sooner than expected. Can anyone advise me would I also need to change flywheel also if clutch plate not fully worn and why? I have a vec 1.9 cdti 2006
    Engine : 1.9 CDTi
    Does it only make the noise when your on lightly on the peddle and go when you fully press it?
    Feb 2011
    london
    yes noise and slight vibration when pressing pedal...clears when released
    Engine : 1.9 CDTi
    Its normally sign of the dual mass flywheel failing
    Feb 2011
    london
    Thanks Lee..... not good news but car has done 107,000 and still original clutch so must be due for clutch replacement. I've seen a Vec 1.9 cdti advertised with recent new clutch fitted and only done 55,000 miles....either the car is clocked or they live in a hilly area or car pulling caravan or trailer..anyone else had a clutch replacement with lower miliage?
    Regular Member Craig1985's Avatar
    harwich essex
    Had mine done at 47k due to dual mass flywheel problems. A common problem
    Southport
    My CDTi 150 106k has the thrust bearing noise its been there for approx 2,000 miles so im not worried i will wait until it gets worse or fails. It does not affect the driving or changing gears etc just a bit noisy with the clutch pedal out but only noticable when stationary, if i press the clutch pedal to the floor the noise goes away completely.
  1. Worn Thrust Bearing?
    By LeeU in forum Y & Z30DT Specific
    Last Post: 9th August 2012, 09:24
  2. Clutch Thrust Release Bearing Perhaps.?
    By sootyville in forum Engine & Drivetrain
    Last Post: 24th July 2011, 07:58
  3. Thrust Bearing 1.9cdti 120
    By stevie16v in forum Engine & Drivetrain
    Last Post: 11th May 2011, 18:08
  4. DMF or Thrust bearing
    By skidmark1 in forum Vectra C / Signum Car Chat
    Last Post: 26th January 2011, 20:52
  5. 3.2 GSI Thrust/Clutch bearing Question.
    By gsi32 in forum Engine & Drivetrain
    Last Post: 4th February 2009, 13:45
vauxhallvectrathrustbearing
vectra thrust bearing noise
