Page 1 of 4 123 ... LastLast
Results 1 to 10 of 37
Thread: Bio diesel help
    Regular Member winnie2457's Avatar
    kings lynn, norfolk
    Default Bio diesel help
    I know this has been asked many times but nit had a definate honest answer or any one with experience
    I I mixed 50/50 diesel and bio diesel in my vectra 1.9cdti will it do any damage as says on a website all diesel cars even common rail can use it
    I know ppl who have ran 2006 ford Mondeo tdci on kerosene (jet fuel) before for many years with no problems mixing it 70/30. 30 being diesel
    And still going strong today.
    So would a 50/50 mix of biodiesel in a vectra cdti be ok as I can get a biodiesel processor for 100quid which makes 80litres every 2 days
    You first filter the waste veg oil through a 25mkcron filter then again through a 10micron filter. Once this is done you mix it with certain % of methanol and caustic soda then leave in the processor barrel with a heating element in set to a certain temp over 24hrs and done it's ready to use.
    What's your views.
    It's filtered so won't block anything plus has to pass though fuel filter in car 1st
    It's mixed with methanol and caustic soda so it won't freeze and prevents waxing plus bein mixed with diesel it won't be much different
    And I know you can run old diesels on pure veg oil with White spirit so can't see much harm with modern cars
    Any views or experience or comment would be great and don't just say it will break the car as I can't see it unless you explain how it will thanks
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Engine : 2.0 TDI 184PS
    Mileage : 40000
    Don't use it in the CDTI's. They don't like it and one of things it can damapge the seals in the fuel line not to mention the pump. Stay away.
    Gazza4
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Try it, then if your car goes we'll know why we shouldn't use it
    Vehicle : vectra-c
    Trim : sri
    Engine : cdti
    Mileage : 98,000
    if you look some garages like Morrison's already have 7% bio added, most people don't even know there putting it in, there's nothing wrong with kerosene but apparently is less lubricating than diesel ?.
    Regular Member Celes's Avatar
    Slovenia, Koper
    Vehicle : Opel Signum
    Trim : Sport
    Engine : 3.0 CDTI
    Year : 12/03
    Quote Originally Posted by the-wizard View Post
    Also in Germany, all fuel stations I used use 7% of bio stuff in their diesel
    Nov 2010
    *!dave!* - The Black Country
    Until such time as Bio-Diesel is asigned a BS number I would keep well clear as the quality varies between sellers who often are trading unlicenced from an Industrial Estate
    The "Bio-Mix" being sold at some "official" fuel retailers is made to a particular standard but check with your cars manufacturer BEFORE using it
    Full Member
    Jun 2007
    N/A
    Vehicle : Golf 7
    Trim : GTD
    Mileage : 40000
    Most know that but 50/50 is too strong a mixture.
    Gazza4
    stockport
    Exclamation
    Quote Originally Posted by RS2000CUSTOM View Post
    Using it also voids any warranty you might have on the vehicle,or so I have been led to believe????. FELIXX.
    The only person I know who used it was MTC in his signum. Filled up with it by accident in france when coming back to the uk. IIRC he just about crawled up the slope from the port and had to change all the fuel filters and clean the lines.
    This was a one off fill up.
    Regular Member John3v36's Avatar
    NI
    i have a 2.0dti and i used to fill it up with bio wherever i could get it - no problems whatsoever.
    i went to one 'garage' and put some 'diesel' in and the fumes smelt more like home heating oil being burnt!it took a while to start.
  1. Slight diesel leak from Diesel filter housing :-(
    By rollercoaster63 in forum Engine & Drivetrain
    Last Post: 22nd July 2015, 21:18
  2. V POWER DIESEL Vs DIESEL
    By OSSY in forum Vectra C / Signum Car Chat
    Last Post: 1st December 2009, 21:22
  3. BP Ultimate Diesel vs Morrison's mucky Diesel
    By Big Knox in forum General Chat
    Last Post: 31st March 2009, 13:11
  4. Shell Diesel Extra Or BP Ultimax Diesel
    By tonyx420 in forum Vectra C / Signum Car Chat
    Last Post: 11th July 2007, 13:25
  5. 2.0 Diesel
    By cp123 in forum Vectra C / Signum Troubleshooting
    Last Post: 17th December 2006, 23:50
ford tdci kerosene mix
Vauxhall insignia 2.0tdi bio deisel
https:www.vectra-c.comforumshowthread.php130250-Bio-diesel-help
