Thread: wierd brake feeling
    lincoln
    Default wierd brake feeling
    wonder if anyone can help
    basically when i press the brake pedal it starts going down then suddenly goes like a quarter of the way down then starts working but they dont feel as good as usual. I haven't done anything or changed anything other than painted my callipers. it has had new discs and pads less than 3 months ago also i changed the two vacuum pipes from standard ones too blue ones will this have made a difference.
    any help appreciated
    Regular Member crispy007's Avatar
    Oct 2010
    lincs
    sounds to me like you have air in the system try bleeding them the longest brake from the master cylinder 1st the shortest 1 last
    Forfar, Scotland
    Trim : LE/VXR
    Engine : 2.0 cdti/1.6 Turbo
    Year : 13/07
    Have you checked the brake fluid? If it's gotten low you may have to top up and bleed the brakes. Failing that if you've not had the system in bits and have no leaks I think you may be having master cylinder problems
    lincoln
    brakes having been in bits at all and the fluid is full
    luton
    mine is vac sys prob as if i spray silicon lube in to vac sys they behave norm then after a few days go bad again taking vac sys appart tomos
    Regular Member Eskimo's Avatar
    Feb 2011
    Scotland
    twice now when I've pressed the brake after starting the car the feel has been as though the engines wasn't running then suddenly has gotten better. Any ideas what this could be and is the pedal likely to go non servo assisted while driving?
  1. wierd problem
    By ste_goffy in forum Engine & Drivetrain
    Last Post: 16th December 2009, 01:01
  2. Wierd Noise.
    By seanyis in forum Electrical & ICE (including SatNav)
    Last Post: 6th April 2009, 14:09
  3. Wierd Problem with Key / CL
    By shatz in forum Electrical & ICE (including SatNav)
    Last Post: 18th October 2008, 18:45
  4. Its a wierd one but need help!
    By Kyser143 in forum Vectra C / Signum Car Chat
    Last Post: 10th June 2008, 21:29
