Thread: Clutch Pedal Vectra 2.0T
    Apr 2008
    Nottinghamshire
    Question Clutch Pedal Vectra 2.0T
    Last wednesday as I parked the car I went to put the car in reverse, I pushed the clutch pedal and it dropped to the floor ( felt similar to a cable snapping and I should know as I had a cav that would get through a cable every 2 months !). I thought the worst i.e some major hydraulic failure but found the clutch still worked even though it was like a switch with the tiny amount of pedal travel I still had. I somewhat jerkily drove home and examined the car but could find no leaks etc , fluid resevoir still full. Had a look at the pedal and when I pulled it up by hand it satyed there. I took it out for a drive and all was fine. I have done 150 miles since and all is fine. Is this just the spring acting up or can I get ready for a hefty bill???
    Apr 2008
    Nottinghamshire
    Default Update
    Just an update , put another couple of hundred miles on and still fine , anyone any ideas?
    Regular Member Torque's Avatar
    Oct 2010
    Plymouth
    Sounds odd. If it's still working after 250miles I can't imagine it being anything major.
    leeds
    Thats a common problem. The return spring on the pedal box breaks. iirc it is a pig to change, pedal box out and an all day job... However if you ask for the modified spring it just fits easily - part no 9318 3937
    There is a white plastic holder for the spring, just behind the pedal. The holder will be empty (why?!) so put the spring in there.
  1. clutch pedal really soft after new clutch
    Last Post: 3rd February 2013, 14:52
  2. Clutch pedal to the floor vectra 1.8 52 plate
    By chubbs21 in forum Engine & Drivetrain
    Last Post: 13th September 2012, 00:35
  3. Brought A vectra yesterday and the clutch pedal has dropped?
    By johal87 in forum Vectra C / Signum Car Chat
    Last Post: 24th January 2011, 11:13
  4. clutch pedal
    By Tam80 in forum Engine & Drivetrain
    Last Post: 2nd September 2010, 19:41
  5. Clutch Pedal!!
    By andd306 in forum Vectra C / Signum Car Chat
    Last Post: 25th March 2010, 21:48
