Thread: 1.9 cdti 120 Thermostat Mod
    Jun 2009
    birmingham uk
    Vehicle : Vectra C Estate
    Engine : 1.9 CDTi
    Mileage : 106000
    Default 1.9 cdti 120 Thermostat Mod
    My cars suffering from the failed thermostat ie stuck open and looking at the work involved to replace it I'm thinking about just cutting the thermostat to radiator hose and fitting an in line housing/thermostat unit. Wonder if anyone as already tried it and what results they have, or parts used.
    Regular Member robengland9's Avatar
    Feb 2011
    london
    Not heard of anyone fitting a thermostat to radiator hose but cant see why it wont work. The only problem I can think of it being in a different position and not directly in contact with engine is it might take longer to heat up and open then cause engine to overheat... I might be wrong but just a thought.
    Jun 2009
    birmingham uk
    Engine : 1.9 CDTi
    Mileage : 106000
    Thought about the temp difference being in the hose so plan to mount it as close to the original thermostat as I can and start off with one that opens at 82 degrees. Need to find a housing suitable or see if I can make one.
    Regular Member Mopar Man's Avatar
    herts
    Jobs not that bad 2and half hours at the most on a 120.
    There are many pipes coming off the thermostat housing that need heating up before the thermostat opens.
  1. thermostat 1.9 cdti 120 and 150 is it the same?
    By grabos in forum Engine & Drivetrain
    Last Post: 7th January 2013, 17:35
  2. 1.9 CDTI 8v THERMOSTAT
    By GSiSnash in forum Engine & Drivetrain
    Last Post: 7th September 2012, 19:17
  3. 1.9 CDTI thermostat
    By Ginge7289 in forum Engine & Drivetrain
    Last Post: 27th January 2011, 07:07
  4. 1.9 cdti thermostat
    By ruby2009 in forum Vectra C / Signum Car Chat
    Last Post: 1st February 2010, 17:51
https:www.vectra-c.comforumshowthread.php130218-1-9-cdti-120-Thermostat-Mod
1.9cdti 120 mods
vauxhall elephant hose mod
vectra cdti thermostat mod
thermostat for a vauxhall zafira 19 cdti
vectra cdti 120 elephant mod
1.9 (120) vectra c cdti 2008 thermostat location
thermostat stuck open 1.9cdti
vectra c thermostat 1.9 cdti
vauxhall vectra 1.9 cdti thermostat
vectra c 1.9 cdti 120 thermostat
vectra c 1.9 cdti (120) thermostat location
vectra 1.9cdti thermostat stuck open
