Thread: help needed with interior lights not working
    Feb 2011
    Kettering
    Exclamation help needed with interior lights not working
    My 03 Vectra's interior lights seemed to have stopped working and the lights on the dashboard where speedo is are not working either, could this be a fuse blown or something more? every other light works just not the interior
    and i also have the wiper problem but after reading other posts on here i've found out its the wiper motor so thanks for that guys
    Dunstable
    Try looking in the passenger fusebox, it's at the end of the dashboard under the cover and look at fuses F17 - 15A and F26 - 7.5A They're both for "Instruments & Info Display". I take it everything else works, windows, other lights, hazard lights etc. Does the interior light come on when you open another door or still stay off. There is a button on the interior light unit which disables the light coming on, so make sure this isn't pressed in too. Hope that helps!
    Feb 2011
    Kettering
    cheers for the info everything else works in the car and have looked at fuses which are all fine but there is still no interior light or display light on speedo but all lights such as indicator or hand brake and cruise control etc all them light up
    Feb 2011
    Kettering
    Have now sorted dashboard lights after reading other forum subjects on here (so thanks for the helpful posts) it was the fuse for the battery overload protection as my car was in my local vauxhall garage for a week to have a new electric window switch fitted on drivers side i have to blame them because it worked before it went there, it seems they may have taken the fuse out (number 12 from the fuse box on passenger side near glovebox) and put it into fuse number 4 when they replaced and according to my manual fuse 4 is nothing so took that 15amp fuse and put it in there and it now works, all i need to do now is replace my wiper motor as that worked before the car went in and now it doesn't, does anybody know of a good vauxhall parts place which is reliable as i dont really want to buy one from my local vauxhall dealer ?
    VIP-Member
    Dec 2010
    London
    Engine : Z18XER
    Feb 2011
    Kettering
    cheers for that seems easy to do so will keep me busy for about an hour
  1. heator blower, interior lights not working
    By frenchman in forum Bodywork & Interior
    Last Post: 12th September 2012, 19:02
  2. changed interior lights, now none are working. :s:s:s
    By amand in forum Electrical & ICE (including SatNav)
    Last Post: 16th August 2012, 09:12
  3. Interior Reading Lights front and rear not working
    By Gavin Thomas in forum Electrical & ICE (including SatNav)
    Last Post: 18th July 2011, 16:54
  4. Dash switch backlighting and interior lights not working...
    By Penfold101 in forum Electrical & ICE (including SatNav)
    Last Post: 3rd December 2009, 00:03
  5. dashboard and interior lights not working
    By raymondlhuk in forum Bodywork & Interior
    Last Post: 26th January 2008, 20:21
vauxhall vectra c interior lights not working
vectra interior light fuse
vauxhall astra interior lights not working
2005 vectra interior lights fault
vectra c battery overload fuse
Vectra c interior lights not coming on when opening door
2008 vauxhall vectra interior lights not working
vauxhall zafira a interior light fuse
vectra c interior light fuse
vectra c interior light wont work
2006 vectra interior light not working
vauxhall vectra interior light not working even with new unit
vektra c interior light problem
2008 vectra c interior light fuse
zafira 2007 no interior lights
My interior lights not working on vauxhall zafira
interior lights not working 2009 vauxhall zafira
