Thread: keep loosing all dials and spanner comes on (seems to be a common fault)
    grantham
    confused keep loosing all dials and spanner comes on (seems to be a common fault)
    Have started loosing all the dials on the dash. Revs, Speedo, Temp, Fuel. Spanner comes on and the traction control light. It started with them dropping for a second or two, then going back to normal. But the TC light would stay on. Went out tonight and this happened again. Only this time the steering wheel with the exclamation mark also came on with the spanner. Also the battery light. Had a new alternator fitted last month, seemed to have started a few days after. This is an intermittent fault and seems to be worse if the weather is cold. Ive got an 2003 2.2 petrol not the direct. My work mate has got an 3.2 gsi on a 52 plate. He has got the same problem with his. Anybody got any ideas before i hand over my wallet to the stealers.
    West
    get the alternator tested
    Regular Member crispy007's Avatar
    Oct 2010
    lincs
    just try the battery leads to see if they are loose wife saxo did this and thats what caused it
    grantham
    alternator is charging ok. had a new one fitted just last month and the battery leads are all good.
    West
    I know you said it's a new alt... but it has been known to be a faulty new part.
    hth
    Ashington, Northumberland
    Two common causes, 1) CIM module in the steering column, 2)dirty contacts on the ABS multiplug/ABS plug not secure.
    Theres loads of info on here about them both, just have a search and you'll find lots of people have had these problems.
    grantham
    thanks Gary. you've hit the nail on the head with this one bruv. got wed, thur & fri off so will have a look at it then. hope its the nice cheap fix (abs multi plug) and not the CIM. thanks for pointing me in the right direction.
    north east
    Have a look at this discussion thread and how to.
    http://www.vectra-c.com/forum/showth...14186&posted=1
    grantham
    gave the abs plug a bit of a whack the other night. made a difference straight away, so have given the abs plug a good clean and a spray with electrical connector. put it back together and the car is all good again. happy days.
    Regular Member badback's Avatar
    Runcorn
    "gave the abs plug a bit of a whack the other night" I generally use this method. Glad you're sorted mate. This forum is so helpful.
  1. Common Fault
    By Madmarky01 in forum Vectra C / Signum Car Chat
    Last Post: 28th July 2012, 00:13
  2. common fault. so I thought
    By mattyj33 in forum Troubleshooting
    Last Post: 10th December 2011, 22:25
  3. Help Please, 2.2 DTi Common Fault?
    By chrisschild in forum Engine & Drivetrain
    Last Post: 8th December 2010, 11:05
  4. It appears its a common fault
    By gary k in forum Engine & Drivetrain
    Last Post: 17th February 2009, 10:34
  5. is this a common fault
    By don paul in forum Electrical & ICE (including SatNav)
    Last Post: 24th January 2009, 11:21
