Results 1 to 10 of 16
Thread: Automatic (cvtronic) gear surround removal - help
    Regular Member influencd's Avatar
    Oct 2010
    Eversley
    Default Automatic (cvtronic) gear surround removal - help
    Heya,
    I've been hunting down an annoying rattle for quite some time and I'm 99% sure that it's coming from inside the center console, right down under the gear selection lever. Apologies in advance if this has been covered somewhere but have looked pretty hard...
    It's an '04 2.2 DTi automatic (cvtronic) SRi
    The rattle starts along with higher revs, plastic clicking, enough to completely ruin the engine note and is driving me bonkers. It stops sometimes so I think there's something loose.
    I've had some of it apart:
    1) Removed the shelf under the CD player
    2) Removed ash tray
    3) Removed tray under ash tray
    4) Removed lighter socket surround
    5) Removed the gear lever (chrome bit) surround
    Here's where I get stuck. How do you take off the next bit - the selection lever panel. Does the gear knob have to come off?
    I've tried prying the panel up and have got it out a bit, but it doesn't seem to go back in properly, there must be a right way of doing it.
    Any instructions / advice on how to get to the space below would be well appreciated!
    I've got a haynes but helpfully it doesn't cover the cvtronic...
    ta!
    Oct 2010
    Eversley
    At the hope of a bump. I'm talking about whipping this bit of grey plastic off:
    I can't believe with all the mods / repairs on here no-one has ever taken it off
    What's the trick? Need to get this rattle sorted before I'm carted off in a straightjacket!
    morecambe
    41 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    er it looks as if you put it in ti'p the maybe it might pull off mine is auto but never tryed
    Oct 2010
    Eversley
    Yeah see you can only get it up by half inch or so and it hits on the base of the gear knob. It looks glued together though and I wonder if it will only come apart once...!
    morecambe
    41 Post(s)
    Vehicle : vectra
    Trim : vxr
    that could possibly be it mate but i would of thought it would come apart
    Oct 2010
    Eversley
    Ah well cheers man, I'll keep on tryin. If any tinkering genius can share their wisdom it would be appreciated!
    morecambe
    41 Post(s)
    Vehicle : vectra
    Trim : vxr
    gonna go look at mine
    Regular Member Aikon58's Avatar
    Englandshire
    Vehicle : shatch- sports hatch
    Trim : cheap plastics
    Engine : metal
    Year : 1901
    Mileage : 999
    I took my auto stick cover off my old car before,it never went back the same and would move about and the plastic gaitor would crease up,so i had to remove it
    This man looks like he had more success
    http://www.vectra-c.com/forum/showthread.php?t=118768
    Regular Member omega63's Avatar
    Jul 2010
    Droylsden, Manchester
    Vehicle : Insignia 2.0L CDTI SRI hatchback
    Trim : Black leather
    Engine : A20 DTJ 128 HP
    Mileage : 126,000
    Thumbs up
    Quote Originally Posted by influencd View Post
    If you flick out the silver panel at the rear of the g/lever, in side the lever/handle there is a nut. You will need to undo this nut and remove the handle, becareful when removing the lower panel as below there is some "micro wiring loom" below...
    Oct 2010
    Eversley
    What a legend, thank you!
    Easy when you know how, I'll give it a bash later.
  1. Automatic gear selection removal help
    By influencd in forum Bodywork & Interior
    Last Post: 31st May 2011, 18:53
  2. 2004 vectra 3.0 v6 diesel automatic gear box
    By vectra 3.0v6 sri in forum Vectra C / Signum Car Chat
    Last Post: 21st November 2010, 23:05
  3. 2.2 sri automatic gear box problem help
    By joner sri in forum Vectra C / Signum Car Chat
    Last Post: 12th September 2010, 21:26
  4. Notchy 3rd Gear Automatic
    By WeDesign in forum Vectra C / Signum Car Chat
    Last Post: 30th November 2009, 18:24
  5. Heater control surround removal
    By Ste in forum Vectra C / Signum Car Chat
    Last Post: 6th December 2005, 11:47
VECTRA C REMOVING AUTO GEAR SURROUND
