Results 1 to 10 of 15
Thread: VXR instrument dial test
    Regular Member hothatch's Avatar
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Engine : 1.6T 180 ECOTEC
    Year : 2012
    Default VXR instrument dial test
    Attention VXR Owners.
    Can some one just confirm if this is true, i went to car supermarket and looked at a vectra vxr i stuck the key in the key hole and turn it to ignition and all the needles in the instrument dial moved from the 0 position to full on and then back to 0. Now somebody has told me it does that cause the cars in a safety mode to stop you driving off.
    That's a VXR thing mate - I believe you can fit the clocks to any petrol Vectra and they'll do the same thing...
    Oct 2009
    portland
    Vehicle : Bmw 330d
    Trim : Msport
    Engine : 3.0d
    No just looks good
    Full Member
    South West
    Quote Originally Posted by Penfold101 View Post
    Ill confirm they will fit and work fine in an SRI.
    The swinging dials are purely cosmetic from what i read before i got a set.
    Rgds
    Aidi
    morecambe
    42 Post(s)
    Vehicle : vectra
    Trim : vxr
    Engine : 2.8 v6 turbo
    I wonder I they will work in my elite
    Full Member
    South West
    Dont see why not mate.. The bummer is the milage difference. You can get it changed to match your existing clocks.
    I only had mine for a couple of weeks.. There was too much red on the speedo for my liking.. so went back to my SMD converted originals.. which IMO look sooo much better!
    Only bought them for the swing dials, but the novelty of that soon wore off to!
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Year : 2012
    Thanks. Strange The guy that told me this works for a vx breakers yard, so i thought he was right,but I still not so sure so wanted a confirmation from vxr owners. My car is Sri cdti unfortunately so probably won't be compatible
    Full Member
    South West
    I dont see why it wouldnt work mate... Should just plug in and off you go. Hopefully someone can confirm this though.
    Nottingham, emec#7
    Vehicle : Insignia
    Trim : SRI NAV
    Year : 2012
    Ok so wondering if anyone has install it on a diesel Sri
    It would probably work ok, but the rev range is different on the diesels as is the top speed reading on the speedo (I would imagine) so i don't believe they're compatible...
  1. OPC/VXR dial in a CDTI
    By emsedk in forum Styling
    Last Post: 12th November 2012, 21:20
  2. dial smd type
    By beat275 in forum Vectra C / Signum Car Chat
    Last Post: 5th February 2012, 20:32
  3. dial change!
    By vec-cal in forum Styling
    Last Post: 8th May 2010, 23:14
  4. Dial lights on!!!
    By Johnty in forum Vectra C / Signum Car Chat
    Last Post: 18th January 2010, 17:47
  5. Dial up help required....
    By glenboy in forum The 'Off Topic' room
    Last Post: 27th May 2008, 12:58
